Front Turn Running light problem
Old Jun 8, 2012 | 10:33 PM
garybg1's Avatar
garybg1
Default Front Turn Running light problem
My right front DTR/turn signal light keeps burning out and frying the socket. Checked the voltage and it seems ok. Any ideas?
Old Jun 8, 2012 | 11:53 PM
kris6868's Avatar
kris6868
Are you putting LED's in them or regular bulbs?
Old Jun 8, 2012 | 11:58 PM
jrose7004's Avatar
jrose7004
Is water getting in there?
Old Jun 9, 2012 | 12:15 AM
garybg1's Avatar
garybg1
regular bulbs, stock sockets from the GM dealer. This is the third set in 4 weeks.
Old Jun 9, 2012 | 12:16 AM
garybg1's Avatar
garybg1
No, it has been dry here until today. No rain or water to affect the lights.
Old Jun 9, 2012 | 03:37 AM
DeeGee's Avatar
DeeGee
The DRLs burn the housing which lets water in. Even though it hasn't rained you'll find water gets in there when you wash it.
You need to pull the housing and inspect the plastic unit for damage. You also need to check the connectors for dirt and corrosion. If the housing is burned you can run a bead of silicon sealant to fix it.
I'll dig out an old post and post it up
DeeGee's Avatar
DeeGee
Default Pulling the TS Housing
Melted turn signal housings are common and its a design problem on all C5s. The turn signal bulbs are dual filament and act as park, turn and DRLs. The heat of the DRLs being on constantly burns the housing. I had to inhibit the DRLs here in England as ambers are not legal here. I never have T/S bulb failures and my lenses are still sound. The most common symptom is that the bulbs fail regularly because water gets into the bulb holder.
You can inhibit the DRLs by pulling the A2 fuse but if you want to keep the DRLs, LEDs are the way to go. LED bulbs produce less heat and are less likely to damage the housing. If you fit LEDs you’ll need a ballast mod to prevent “hyperflashing” as the system doesn’t recognize the LED bulb and thinks it’s failed. (JWMotoring sell a harness which will fix that issue).
Pull the housing – I’ve attached a procedure below – and inspect it. Others prefer to go in through the headlight housing but its harder to see the fixtures. You’ll probably find a hole on top. If it’s not too bad seal it with silicon sealant and reinstall the housing. That should fix the problem for now and the silicon may be enough to stop it getting worse.
Document ID# 655625
2002 Chevrolet Corvette
________________________________________
Park/Turn Signal/Side Marker Lamp Replacement
Removal Procedure
1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
2. Remove the front fascia lower closeout panel.
3. Release the brake caliper cooling duct from the front fascia, and position the duct aside.
4. Remove the front turn signal lamp bracket retaining spring from the lamp bracket.
5. Remove the lamp bracket retaining spring from the front fascia.
6. Remove the front turn signal lamp bracket retaining screws.
7. Disconnect the sockets from the lamp.
8. Remove the lamp, with the bracket, from the vehicle.
9. Remove the lamp to bracket retaining screws.
10. Remove the lamp from the bracket.
Installation Procedure
1. Install the front park/turn signal and sidemarker lamp into position on the front turn signal lamp bracket.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
2. Install the front park/turn signal and sidemarker lamp to bracket retaining screws.
Tighten
Tighten the front park/turn signal and sidemarker lamp to bracket retaining screws to 2 N•m (18 lb in).
3. Install the sockets to the lamp.
4. Install the lamp, with the bracket, to the front fascia.
5. Align the lamp to the opening in the front fascia and hold the lamp firmly in place against the fascia, while installing the front turn signal lamp bracket retaining screws.
Tighten
Tighten the front turn signal lamp bracket retaining screws to 3 N•m (27 lb in).
6. Install the lamp bracket retaining spring to the front fascia.
7. Install the front turn signal lamp bracket retaining spring to the lamp bracket.
8. Position the brake caliper cooling duct to the front fascia and press the duct toward the fascia to secure.
9. Install the front fascia lower closeout panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers.
Old Jun 9, 2012 | 02:26 PM
Jistari's Avatar
Jistari
What he said
[IMG][/IMG]
[IMG][/IMG]
Old Jun 9, 2012 | 06:09 PM
garybg1's Avatar
garybg1
Thanks for the article and your time searching. I will try a sealant. I have not found any cracks but I know if there is a opening water will find it. I appreciate the information.
Gary
Old Jun 9, 2012 | 08:41 PM
02koolC5's Avatar
02koolC5
just an idea but, just make sure that the bulb "snaps" in socket...I chased that issue also and found I haven't been connecting it properly....good Luck
To Front Turn Running light problem
