Plug wire question
Old Jul 27, 2012 | 03:02 PM
cmessineo's Avatar
cmessineo
1st Gear
Default Plug wire question
Hi all, I'm changing out my old plug wires and was wondering if you can leave the factory metal sleeves off. I'm replacing with GM Red wires.
Old Jul 27, 2012 | 03:16 PM
TOPCATHR's Avatar
TOPCATHR
the new wires are usually heat resistant. i put mine back on.....cant hurt
Old Jul 27, 2012 | 04:33 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
You'll get a whine on your radio without them
Old Jul 27, 2012 | 04:46 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
Well I've been running without them for years without any whining . . . well every once in a while some of the female voices drive me nuts, but I've never noticed the whine.
rr
Old Jul 27, 2012 | 04:51 PM
NukeC5's Avatar
NukeC5
Haha^^^
OP, you should be fine without them. I dont have a problem with them off.
Old Jul 27, 2012 | 04:56 PM
bighank's Avatar
bighank
Default Put them back on - whats the problem
When I did plugs and wires I got the red ones from Gene. The metal cans fit perfectly just like on the black wires. Put them back on and be done with it.
Old Jul 27, 2012 | 05:07 PM
andrec10's Avatar
andrec10
Just did my plugs and wires. MSD wires and NGK plugs. The metal things wont fit over the MSD wires...
Old Jul 27, 2012 | 05:27 PM
KillSwitchNY's Avatar
KillSwitchNY
I did MSD wires and kept them on, They are a little loose since the boot is not designed for the shells. It will prolong the life of the boots slightly if you keep them, but I doubt it's much difference. I actually also slipped the shells into the Taylor fiberglass socks for double resistance from the turbo manifolds. Just food for thought.
Old Jul 27, 2012 | 11:55 PM
Did the same thing when I changed out the plugs/wires on the '00 I had. Fit perfectly.
Old Jul 28, 2012 | 12:00 AM
yaknow's Avatar
yaknow
replaced mine with gm reds with the metal guards 2 years ago, no problems
Old Jul 28, 2012 | 09:08 AM
Corvette_Ed's Avatar
Corvette_Ed
The engineers at GM went through the trouble of including the shields in the design of the C5 Corvette for a reason. Use the shields.
Old Jul 28, 2012 | 09:12 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Over 5 years on red gm wires without the Shields and no issues here.
To Plug wire question
