Help - Need hub nut size
Old Aug 2, 2012 | 12:45 PM
Corvette_Ed's Avatar
Corvette_Ed
Default Help - Need hub nut size
Does anyone happen to know the size of the nut on the hub that holds the brake rotor on to the axle? Chevy dealer can't tell me and I need to know which size socket to get so I can get the front & rear rotors changed out. If there are any others on there that I can't see I'd need those sizes as well.
Thanks.
Old Aug 2, 2012 | 12:55 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Does this help?
http://forums.corvetteforum.com/c5-g...nd-rotors.html
Old Aug 2, 2012 | 01:12 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
I think it's either 33mm or 34mm. Torque is 115 to 118...I give this figure because I think on the c6 which uses the same nut they increased the torque spec. I tightened mine to 118
Old Aug 2, 2012 | 01:26 PM
Corvette_Ed
Originally Posted by JW@JWMotoring.com
Yes, thank you, it does as far as the brakes go, and if it was physically possible I'd kick myself right about now. I'd still like to know the size of the hub nut though. While I have everything apart it would probably be a good idea to go ahead and repack the bearings.
Old Aug 2, 2012 | 01:30 PM
JW Motorsports
Banned Scam/Spammer
This one?
If so it's 33mm. Taken from this thread http://forums.corvetteforum.com/c5-g...e-junkman.html
Old Aug 2, 2012 | 01:33 PM
Corvette_Ed
That's it, thank you. Looks like I'm going to need a bigger torque wrench too.
Old Aug 2, 2012 | 01:37 PM
02z06dave's Avatar
02z06dave
You don't have to take off the hub nut to change the rotors
Old Aug 2, 2012 | 01:43 PM
Corvette_Ed
Yes, I see that now, thus the comment:
At any rate, it's well over 100 degrees already so this job is going to be put off until tomorrow.
Old Aug 2, 2012 | 01:49 PM
JW Motorsports
Banned Scam/Spammer
Yep probably another 112 degree day up here. Way too hot to be out there.
Old Aug 2, 2012 | 02:27 PM
02z06dave's Avatar
02z06dave
I'm glad my garage is insulated with a/c
To Help - Need hub nut size
