Iam going to start my cam swap job on my 03Z soon. Iam installing a Comp Cam XR275HR and I need some advice please.
1. Can I run the factory timing chain? It has 36000 miles on it.
2. Do I really need to pin the harmonic balancer?
3. Iam not going to remove the heads so what brand of valve spring
compressor will work best.
Thanks for the help.
At a minimum I would change to the ls2, but I prefer a coyles or katech double roller. pinning the balancer is not mandatory, but most shops prefer to do it. I can't help you on the valve spring compressor. Do you have headers, or are you adding those also? Back in 04 I was cam only, no head work, with headers I had 430 rwhp 380rwtq.
I did my cam swap at 26k miles. I have an 03 Z as well
Your stock chain should be fine, its still practically new. I cant see replacing perfectly good parts as a "precaution". If you had higher mileage or were going with a radical cam it would make more sense.
I didnt pin my crank. Should only really be necessary if you are running a supercharger, which applies more load on the pulley. If this is something you may add in the future then do it now to save the headache later.
I used a cheap, but very effective tool developed by an LS1tech forum member. He sells it on ebay for $38. There are more expensive tools that allow you to do two springs at once... but how many times are you planning to do this job? I couldnt justify spending 2-4 times the money for somethign that becomes a decoration once the job is done
