Wheel question
Old Aug 10, 2012 | 08:48 PM
DonsLS1's Avatar
DonsLS1
Default Wheel question
Will the centennial C6 wheels fit on a C5? The front are 19x10 with a 40 offset and the rears are 20x12 with a 59 offset. I have C6 Z06 brakes also. I know the rear will stick out a bit, but nothing to bad. There use to be a pic of a yellow Z06 with C6 Z wheels, but I can't find it anymore.
Old Aug 12, 2012 | 02:08 PM
Russ K's Avatar
Russ K
Compared to a stock C5 ZO6 wheel, the front sidewall will stick out an extra 20mm the rear sidewall will stick out an extra 18mm.
If you don't want the tires/wheels to stick out, you need a 9.5" 54-59mm offset front & 11" 62-65mm rear wheel.
Russ Kemp
