Quick question. How does the bezel attach to the ignition switch? Mine flops all about, I think something broke on it but I'm not quite sure what. I can't seem to get mine to stick to the switch.
The bezel has three slotted openings on the back that line up with three pins on the ignition key cylinder and snap in place. If yours is moving it either came loose from the pins or the tabs of the slotted openings broke. Either way you will need to remove the radio/HVAC bezel to reveal the ignition switch bezel. Before removing the bezel pay close attention to the plastic cord that wraps around behind it so you'll know how to reassemble it correctly.
I have torn mine down a few times with after market HU and White Face gauge install and I noticed mine was loose to. The owner previous to me put a plastic shim in there to help hold it steady. Works good with no movement or play. Hope it works out for you.
