2000 isimple ?????
Old Oct 14, 2012 | 01:22 AM
B-STOCK's Avatar
B-STOCK
St. Jude Donor '14-'15, '17, '19
Default 2000 isimple ?????
I installed the isimple ipod set up in my 2000. I removed the changer and did a plug & play. It works but it will not let me go to a previous song (back) or fast forward etc. I can control the volumn & next song feature from the radio and thats it. I set the dip at 3 8 on. Any hints.
Thanks, Mike
Old Oct 14, 2012 | 02:33 AM
Tron Z's Avatar
Tron Z
Old Oct 14, 2012 | 09:41 AM
James2002z06's Avatar
James2002z06
Default iPod
Thanks, Mike
I have a Kenwood system in mine..... Anyway there is only one large **** on the head unit I can push it right and left to be able to go forward looking for a song or backwards to look for a song
Old Oct 20, 2012 | 04:41 PM
B-STOCK's Avatar
B-STOCK
Anyone??
Old Oct 22, 2012 | 03:19 PM
jsbzoh6's Avatar
jsbzoh6
Mine is kind of tricky. It will not work smoothly just because it is a piggy back interface. I generally stick to not moving forward or back and just letting the songs ride.
Old Oct 22, 2012 | 03:47 PM
B-STOCK's Avatar
B-STOCK
Thanks Renxwar. Mine has no difficulty moving forward but not back. I just wanted to be sure there was nothing wrong with my installation or unit. When I first hooked it up I tried going back with the seek button or the back button but I would have to push it about 3-4 times to go back. Then the IPOD froze. I am fine with just controlling the volume & forward from the HU as long as I know it's working correctly. Thanks for your reply.
Old Oct 22, 2012 | 04:17 PM
HawnHog's Avatar
HawnHog
I hooked one up to my '98 with the Bose's system a few years back and everything works perfect.
Old Oct 22, 2012 | 04:19 PM
B-STOCK's Avatar
B-STOCK
Did you wire it in or use the changer harness?
Old Oct 22, 2012 | 04:22 PM
raydawg357's Avatar
raydawg357
If I remember correctly, once the isimple is plugged in, some of the buttons on your radio take on new meanings. There should be an illustration in the directions. You might be able to find it online.
Old Oct 26, 2012 | 05:45 PM
HawnHog's Avatar
HawnHog
Sorry for the delay.
It was a simple plug an play. The Bose CD controls work just like they did when I had the CD unit.
The kit also comes with two other harness' that allow you to wire the system directly into the back of your Bose unit and/or the wires that are installed in some cars but do not go all the way to the rear. This is IF I remember correctly. I sold both harness' on the cheap to guys thatwanted them.
Old Oct 26, 2012 | 09:19 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Default Good Luck
I have tried two in my 01 coupe, hardwired., Neither functioned at all except passing power to the iphone. Clearly a flaky product at best!
Old Oct 26, 2012 | 09:46 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I have to disagree with you, iSimple is one of the best on the market, Maybe you didn't have the dip switches set right.
Mine worked great when I had it, I now have a DD Pioneer.
Old Oct 26, 2012 | 10:11 PM
Staxmans99's Avatar
Staxmans99
2017 C5 of Year Finalist
, got this product in my 99 and works just fine !
Old Oct 26, 2012 | 10:37 PM
dmarkshark's Avatar
dmarkshark
i have the same issue, but, I know what it will and will not do and learn and deal with it.
To 2000 isimple ?????
