My 2001 has a service required memo on the screen. The left rear tire was a little low on air and I let it go for a while because the weather was cooler.
I filled the tire today to 30PSI and the message is still on the monitor. How do I reset the monitor. It says service required.
Rich from St. Louis:
If you haven't already, take the car for a ride. The sensors have to sense motion to turn back on. Take a 10 minute ride and see if that does the trick.
Love this old vid. Ran this when I bought the car back on memorial day weekend but not since but did just a couple minutes ago and had one HVAC code. No real mods though but I am trying , so maybe I can aquire some lol
Also, it's a good idea to check the pressure in the other tires if you already haven't.
But like damilleniumboy said, if it's reading xxx you're probably looking at needing a new sensor. Be glad they're cheap for the 01-04 compared to the 97-00.
Originally Posted by damilleniumboy
If it has XXX for that tire side onstead of the tire pressure, your pressure sensor probaly went south.
But you might want to just try reprogramming the sensors and see if that helps.
Try that also before spending the money on a new sensor.
