coolant leak
Old Oct 27, 2012 | 12:23 PM
cobra3's Avatar
cobra3
Default coolant leak
Was smelling coolant after driving home from work and found the tank on the right side under the hood to be leaking. The leak seems to be where the black top meets the clear bottom section. Anybody else had any problems with there tank leaking and if so did you fix it or just get a new one.
Old Oct 27, 2012 | 12:28 PM
Corvette_Ed's Avatar
Corvette_Ed
You have to buy a new one. The tank is under pressure so you don't want to attempt a fix unless you want to risk it leaking again. You can get one from your local Chevy dealer or from one of the GM parts vendors here on the forum. This would be a good time to paint the new one before installing if you want to go that route.
Old Oct 27, 2012 | 12:41 PM
cobra3's Avatar
cobra3
Thanks for the quick reply , I will call monday and get one ordered.
Old Oct 27, 2012 | 12:46 PM
Corvette_Ed
Depending on the urgency, check with PartsTaxi.com and GMPartsHouse.com, both GM dealers and vendors here. If you can't wait many GM dealers keep these in stock. I bought one from my local dealership when I needed one and they had several sitting on the shelf.
To coolant leak
