BO441 code ?
Old Nov 3, 2012 | 03:54 PM
steve8's Avatar
steve8
Default BO441 code ?
I have code BO441, which is left actuator out of range regarding hvac.
Second problem is I don't know what that means?
Thanks for the help.
Old Nov 4, 2012 | 12:13 PM
steve8's Avatar
steve8
Old Nov 4, 2012 | 09:16 PM
PoVette's Avatar
PoVette
It's a little box with cheap plastic gears in it. What is does is open the doors in the HVAC system to let in either the heat or the cold.. In my case it didn't let the heat in so I had no heat on my side and my wife was warm on her side... I replaced mine this spring.. took me about 3-4 hrs with breaks and following the replacement guide listed in the tech sticky.
Old Nov 4, 2012 | 09:33 PM
Txsailor's Avatar
Txsailor
My car has set that code ever since I bought it 1 1/2 years ago. The heat and ac work fine right now. When it goes out I plan to replace both of them.
Old Nov 5, 2012 | 05:32 AM
steve8's Avatar
steve8
Thanks for the info.
Old May 24, 2023 | 01:24 PM
fredtman's Avatar
fredtman
5th Gear
Default Left Actuator Out of Range
PoVette - I saw your post from 11-4-2012 concerning code B0441, Left Actuator Out of Range. I couldn't find the tech sticky that you referenced using to replace yours. Any helpful suggestions on how to replace that actuator will be greatly appreciated.
Thanks.
To BO441 code ?
