Ls1 or Ls2
Old Jan 9, 2013 | 08:05 PM
jetmech09's Avatar
jetmech09
Default Ls1 or Ls2
Need your opinion: I am thinking about replacing my hurt LS1 "broke the ring lands" on #7 cylinder, with a Stock LS2 . Or should I rebuild my LS1 with forged rotating parts . I have a A&A V2 supercharger . Was boosting 10 psi .
Old Jan 9, 2013 | 08:15 PM
JaxEagle's Avatar
JaxEagle
What will your cost difference be?
Old Jan 9, 2013 | 08:18 PM
robert miller's Avatar
robert miller
If you are going small ci go with your block, If you want 402 are bigger do the ls2 block and be done with it..
Old Jan 9, 2013 | 09:22 PM
jornahow's Avatar
jornahow
Ls3
Old Jan 9, 2013 | 10:05 PM
jetmech09's Avatar
jetmech09
Est cost to rebuild LS1 would be about 3k but it would be forged.. ls2 average price is around 2,500 plus relacating knock sensor harness and replacing reluctor prob around same cost .
Old Jan 9, 2013 | 10:10 PM
JaxEagle's Avatar
JaxEagle
Tough one. Guess it depends on your goals. If you want a max NA build then I guess the new block but the forged rebuild would be my lean. Keep us posted on what you decide.
Old Jan 9, 2013 | 10:16 PM
NukeC5's Avatar
NukeC5
If cost is about the same, Id say go with larger displacement. If you do rebuild the LS1 with forged internals, would you be planning on upping the boost? Both would make for a good gain in power.. depends on what you have planned.
Old Jan 9, 2013 | 11:51 PM
Vetteriffic's Avatar
Vetteriffic
Go big!!!
Old Jan 10, 2013 | 12:01 AM
p1bz's Avatar
p1bz
For FI go with bore, and not stroke.
Old Jan 10, 2013 | 03:31 AM
onspeed's Avatar
onspeed
cheap iron block + most boost?
Old Jan 10, 2013 | 09:55 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
The stock LS2 is a fantastic bottom end - "BUT"
A forged LS1 is way better and especially since you are already FI - that is the only way to go!
make sure you are running Meth injection or really ramp up your fuel system to handle the Boost - #7 is the one that always goes first and it gets lean, thus breaking your rings!
It won't matter what you put in there if your fuel system is not up to par!
Thanks,Matt
Old Jan 10, 2013 | 11:39 AM
Rickster6744's Avatar
Rickster6744
Agree
Old Jan 10, 2013 | 04:32 PM
jetmech09's Avatar
jetmech09
thanks for the replies. I just purchased a low miles stock 02 ls-1 to get me back in the game . going to install a blower cam and springs and start to overhaul the original engine with forged componets and go from there . thanks everyone for your input>
Old Jan 10, 2013 | 04:38 PM
JaxEagle's Avatar
JaxEagle
thanks for the replies. I just purchased a low miles stock 02 ls-1 to get me back in the game . Going to install a blower cam and springs and start to overhaul the original engine with forged componets and go from there . Thanks everyone for your input>
sweeeet!!
To Ls1 or Ls2
