TPMS going bad?
Old Jan 10, 2013 | 08:46 AM
tdibella's Avatar
tdibella
3rd Gear
Default TPMS going bad?
99 Vert - A few weeks ago my sensor told me me that I have 0 pressure in my RR tire. But it looked fine. so I put a few lbs of air in to satisfy. Then I got a message saying too much pressure on RR tire. so I let air out and was good to go. Yesterday I get the message againsaying 0 pressure but it looks fine. my manual guage can't get a reading but the tire looks fine. Bought the care 10 years ago used and I have never replaced the sensors. Is it time?
Old Jan 10, 2013 | 09:22 AM
LoneStarLizzard's Avatar
LoneStarLizzard
Could be. I have had a similar problem, with one of my sensors on a 2002 periodically giving an xx reading. I re-set it, after checking the air pressure (which is always OK), and keep on going.
But just in case, I have already bought 4 new monitors from GM Parts House, and will install them when I get my next set of tires.
Ya just never know.
The Lizzard
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Have you checked with a tire pressure gauge?
Are they run-flat tires? If so, they won't ever look flat. They are made so you can drive on them for a short time with no air. If you are unsure, you might take it to a tire shop and ask them to check it out. Chances are, the sensor is not wrong. I've not heard of them giving errant readings after giving good readings, and so forth. It's more likely your tire is going flat. (not good). They can wear really fast that way so get it resolved.
Also, the batteries in these do not go dead and then find enough energy to get undead, like might happen with a alkaline battery. When these are dead, they are really dead.
Old Jan 10, 2013 | 09:42 AM
DeeGee's Avatar
DeeGee
You normally get XXX on the DIC if the battery is going bad. If its giving a zero reading it may be working fine. How old are the TPMs?
A runflat feels remarkably stable even when its flat so a flat is entirely possible.
Old Jan 10, 2013 | 10:46 AM
tdibella's Avatar
tdibella
3rd Gear
I used the manual tire gauge and nothing registered. I also tried to put air into the tire but it seemd to act like it wasn't taking any air. Maybe I'll just take it to a tire shop.
heres another something. I've only had the new chrome rims for about 6 months - I got rid of the wagon wheels.
Old Jan 10, 2013 | 10:57 AM
K-Spaz's Avatar
K-Spaz
Well, I think you've just got a flat. It's most likely gonna have to come off to fix it anyway so a trip to the tire shop is in order.
Old Jan 10, 2013 | 11:11 AM
Sonny71's Avatar
Sonny71
Oldtimer
Old Jan 10, 2013 | 11:12 AM
tdibella's Avatar
tdibella
3rd Gear
Thats what i'm hearing from a buddy of mine. Thanks for the responses!!!
Old Jan 10, 2013 | 11:32 AM
jrose7004's Avatar
jrose7004
If you check the pressure with a manual gauge and it's got the right pressure, then the battery is starting to go.
Old Jan 10, 2013 | 04:11 PM
and good luck - hope it is just a flat tire. But, if the sensors are 10 years old, chances are you are living on borrowed time with them.
To TPMS going bad?
