[Z06] Thermostat replacement
Old Jun 11, 2002 | 11:37 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Default Thermostat replacement
The shop manual says that the cooling system needs to be drained when replacing the thermostat. Is that true? I am guessing that DexCool is expensive.
I am thinking about a 178 degree thermo and an adjustable fan controller. The mall lists these parts for 1997 - 2001. Is the 2002 the same part?
[Modified by rbartick, 11:09 PM 6/11/2002]
Old Jun 12, 2002 | 01:40 AM
Power Shifter's Avatar
Power Shifter
Default Re: Thermostat replacement (rbartick)
It can be done just pulling the ts, it will loose 1+ gal but can be cought in an oil drain pan and put back in. Or you could just drain it in the pan, it's not a very big deal and clean up is minimal either way. Ric
Old Jun 12, 2002 | 03:07 AM
SWCDuke's Avatar
SWCDuke
Havoline Extended Life is Dexcool - widely available - Pep Boys, Walmart, etc. - costs about six or seven bucks a gallon. Other vendors also make Dexcool - look for "Dexcool" on the label, but the Havoline Extended life is the original and what GM uses at the plants.
Duke
To Thermostat replacement
