How much do you value TPMS?
Old Jan 15, 2013 | 10:42 PM
JaxEagle's Avatar
JaxEagle
Default How much do you value TPMS?
My dad's '99 needs new TPMS. I am not sure it's even worth it given his purposes. The car has upgraded 1/19 C6 wheels and tires but is otherwise totally stock. He uses the car a nice weather errand car. His main car event ride is a 75 vert.
Anyway, how much do you value tpms? If the car is driven very mildly then it seems that you can just manually keep track of your air pressure by eyeballing it daily and actually checking it weekly or something?
Didn't Z06's start with no TPMS? What year did they start receiving TPMS?
Also, if you have recently bought TPMS, please let me know what you paid and where you bought.
Thanks!
Old Jan 15, 2013 | 10:47 PM
calvins's Avatar
calvins
Oldtimer
The Vette's not here yet but we have them on our Ford Escapes and I like it. My wife picked up a nail and the warning went on giving a heads up.
Old Jan 15, 2013 | 11:02 PM
jdot's Avatar
jdot
My vette has them and this winter they've started reading the two rear tires a couple of pounds low. It has been cold but not severely cold. Last winter they didn't activate at all. I think they're a take it or leave it option.
Old Jan 15, 2013 | 11:15 PM
dblerman's Avatar
dblerman
None of the Z06 came with runflats or TPMS, but the RPO was there in the 01-04 cars so they COULD be added/deleted with a tech II.
I'd say it's a personal choice whether you want to run without them or not. If you're not using runflats, TPMS could save you some money by preventing damage to a rim by giving you an early warning to a flat tire.
I have them on my car...I have AAA but getting a heads up on a flat may just be enough to get me to a tire shop without dealing with a tow truck.
Old Jan 15, 2013 | 11:21 PM
JaxEagle's Avatar
JaxEagle
That is a good point and that could save you in event of a somewhat gradual flat, as opposed to a blow out. Although weekly gauge check and adjustment can reduce chances a little bit. Anyway, good point and I am going to let him make the decision. Just stings spending somewhat significant money on "no fun" parts
Old Jan 15, 2013 | 11:28 PM
RonSSNova's Avatar
RonSSNova
I got about a block from home one morning, and ding ding ding......low tire. No run flats. It had 7psi in it and with these low profile tires, unless you look close, you wouldn't know. My digital tire gauge agreed with the DIC.
Of course someone had mixed up the rears left to right, so it told me the wrong tire, but I would have found out the hard way on the freeway, that would have sucked!
The system gets rather confused when I put the drag radials on.
Ron
Old Jan 15, 2013 | 11:35 PM
JaxEagle's Avatar
JaxEagle
Ron
True! I think I had better have him bite the bullet on the sensors.
Old Jan 15, 2013 | 11:37 PM
f6john's Avatar
f6john
I don't rely on tpms but I really like having it available with direct readings of each tire and it's position. My Nissan Titan has tpms with a warning light and beeper which I could just as well do without.
I have found the tpms to be very accurate compared to my dial pressure gauge.
Old Jan 16, 2013 | 12:28 AM
Choreo's Avatar
Choreo
They have alerted me several times to flats while driving. Had about 7 flats on the C5 the past 13 years. Nothing but roofing nails out here after hail storms.
Old Jan 16, 2013 | 01:06 AM
I like the peace of mind that the TPMS offers - it's on all our cars. Have had several tire punctures over the years and nice to have an early warning that the air pressure is going down.
Old Jan 16, 2013 | 08:20 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I have driven for decades without TPMS, so for me it is not needed, but it is a nice convenience.
If running with runflats (and maybe short sidewall tires) you really can't see if it is low and may not feel it driving either, so TPMS could be worthwhile.
On my '99 I had sensors failing. I did not want to spend over $400 for new sensors. I found Rock Auto had a closeout on the '01 to '04 Schrader (they make the originals) sensors and I talked my local dealer into a better price on the late receiver. I had a couple of fobs that would work too. So I am making the swap to the newer less expensive sensor system and only have about $200 total in the swap. It pays to shop around.
Good luck.
Old Jan 16, 2013 | 08:37 AM
DDaaryl's Avatar
DDaaryl
I have them on my Hemi truck also. Athough they add some value it's just something else to break and maintain. A tuner has the ability to turn them off and make the alarms go away
Old Jan 16, 2013 | 08:56 AM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
You asked how much. I paid $149.99/Free shipping on ebay. Get the right ones, they are different from 97-00 and 01-04. You can also get genuine ones from GM Parts house for not much more money if you'd prefer those parts. When I got mine, the price was in the stratosphere so I got the cheapies, they work just fine.
Old Jan 16, 2013 | 09:08 AM
JaxEagle's Avatar
JaxEagle
Good info, thank you all!
Old Jan 16, 2013 | 11:15 AM
Bill Vett's Avatar
Bill Vett
||--Genuine GM 97-00 Corvette to 01-04 Corvette TPMS Conversion--||
PKC5TPMS - $429.99 (Special Discounted Price)
This kit includes the following:
(1) #1 Key FOB
(1) #2 Key FOB
(1) Remote Control Door Lock Receiver
(1) Remote Control Door Lock Receiver Connector
(4) Tire Pressure Monitoring Sensors (TPMS)
(4) Tire Pressure Monitoring Sensor Mounting Nuts
This kit retails for $685.42 and includes everything you need to convert your TPMS and key FOB’s in your 1997-2000 Corvette to the 2001-2004 Corvette. This is done to change the future costs or current costs of the more expensive 1997-2000 Corvette TPMS and key FOB’s to the lesser expensive 2001-2004 Corvette TPMS and key FOB’s. Click on the link below to purchase.
http://store.gmpartshouse.com/partlo...subcat1=175054
It's is the way to go the cost isn't much more than 4 Gen I sensors and nuts.
Old Jan 16, 2013 | 01:22 PM
3sACROWD's Avatar
3sACROWD
I added them to my 03 Z06 and am happy I did. Since the car doesn't have run flats, I would have damaged the rim without having the TPMS. I was able to monitor the pressure loss and drive to get the tire replaced. I had to stop twice along the way to pump the tire up. A pallet staple went through the sidewall and there was no saving the tire.
Old Jan 16, 2013 | 03:10 PM
raydawg357's Avatar
raydawg357
Being that I don't use run craps anymore, I trust my TPMS. I'd rather be safe than sorry.
To How much do you value TPMS?
Old Jan 16, 2013 | 03:37 PM
memmer's Avatar
memmer
I purchased new TPMS for my 01 C5 vert. at OE WHEEL DISTRIBUTORS for $140.00 plus $5.00 shipping a year ago.I think the 97-04 ones might cost more.
Fred
Old Jan 16, 2013 | 03:49 PM
lt1george's Avatar
lt1george
Good luck.
Correct. The only other thing to do is to have a Tech II delete the RPO. Like the old days without TPSM.
Old Jan 16, 2013 | 03:55 PM
Bill Vett's Avatar
Bill Vett
I'm not sure that can be done with 97 to 00.
