TPMS does not mount
Old Jan 23, 2013 | 08:47 AM
helios_1215's Avatar
helios_1215
Default TPMS does not mount
My one of my 03 vette's TPMS stop working for couple months. so i thought it's time to change it. I bought a ORO TPMS instead of the GM part. after i put it on, i try to use the magnet trick to mount it, but it just won't work. it works for the other three which were GM parts. but the ORO one doesn't. i called the factory, they said it should not be the part's problem, it fits C5s. i just want to know, should i bring it to dealer let them mount or what i should do?
Old Jan 23, 2013 | 09:28 AM
black match box's Avatar
black match box
return it and buy the the GM part. and you will get some good sleep.
Old Jan 23, 2013 | 10:37 AM
Phanni's Avatar
Phanni
Did you buy the proper model for your year of C-5?
the 1997 -2000 models use a different sending unit than the 2001 and up cars. if you bought one for a later model and yours is a early model, it will not recognize the TPMs and visa versa. (you bought early and own a later model)
Old Jan 23, 2013 | 10:48 AM
helios_1215
thanks... but i cannot return it... so just try to make it work now.
Old Jan 23, 2013 | 10:50 AM
helios_1215
mine is a 03 c5. it states on the website, the part i bought is for 01-04 c5. so it should work. i just want to know if the magnet trick works on these ORO TPMS, or it's only for GM parts.
Old Jan 23, 2013 | 11:03 AM
Phanni's Avatar
Phanni
You got me there.
I'd contact the maker and find out.
Like the other guy said, I'd just buy the OEM since they are so hard to get changed.
Old Jan 23, 2013 | 07:59 PM
fevest's Avatar
fevest
replaced two on my 02. Had same problem, even went to dealer and they couldn't get it to go. Wanted to start replacing stuff.
My son had blown up his subwoofer. Used that to train them. No issue and trained as supposed to. Just get a bigger magnet. Oh, dealer used the gm magnet and no go. Just needed a huge magnet.
Old Jan 23, 2013 | 08:16 PM
helios_1215
thanks, got it. i will get a huge magnet then.
Old Jan 23, 2013 | 08:51 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
For 38 bucks just buy the correct one.. Never heard ORO sensor before.
Old Jan 23, 2013 | 08:56 PM
helios_1215
i checked with dealer OEM tpms was 75 each one. so i bough this ORO tek for 30 each.
Old Jan 23, 2013 | 09:01 PM
Mr.Bill's Avatar
Mr.Bill
Never go to the daler unless you have to, Tire Rack sells the same unit GM sells for 38 bucks each, That is why it pays to do your homework, Also AutoZone has them and Kragens.
Old Jan 23, 2013 | 09:07 PM
helios_1215
well, thanks. i learn that now. i'll check it out, if bigger magnet doesn't work.
Old Jan 24, 2013 | 12:50 AM
The '01-04 tire pressure sensors are much cheaper than the earlier C5s use and gmpartshouse.com sells them for around $40. If that sensor you bought doesn't work, I don't understand why the company won't take it back. Anyway, just get a GM one and be done with it - should be no problem with it working properly.
Old Jan 24, 2013 | 05:02 AM
DeeGee's Avatar
DeeGee
The TPM sensor is a complex unit operating at radio frequency. If the TPM you bought is not the correct unit for your model year it will not work as it wont communicate with the radio frequency receiver in the car.
It might be a case of writing it down to experience and get the correct item.
To TPMS does not mount
