Horn Problem
Old Feb 15, 2013 | 05:41 PM
no01k's Avatar
no01k
Default Horn Problem
Horn will not work...Relay and Fuse OK
Old Feb 15, 2013 | 06:40 PM
Jeff in Den's Avatar
Jeff in Den
From the fob either when locking? Not much to it.
Horn switches
Brush Slip rings
Wiring
Horns
Grounds
Try pulling the horn mini fuse 11, and then put 12vdc on the horn wire (dark green) pin B of the horn and see if it blows. That will cut your troubleshooting down some.
This should help.
Old Feb 15, 2013 | 08:35 PM
Crosis's Avatar
Crosis
mine doesnt work either
To Horn Problem
