[Z06] Lowering question zip-bolts or ?
http://www.zip-corvette.com/ProductD...-8af7-4ed1-9d2
Get real friendly with the guys at the alignment shop, you are going to be visiting them frequently. The reason is that when the suspension bottoms out, the shock will wedge the lower control arm outward and this will push the excentrics out and the rear alignment will be screwed up.
Oh and don't expect it to ride or handle worth a crap that low, since the rear will be on the bump stops.
Are you starting to get the impression that this isn't really a good idea?? There are quiet a few threads on the subject of lowering, and lots of folks have found that they are raising the car back up because when you lower it more than the stock bolts allow, there is no rear suspension on the car...
If you are going to lower it that much, after you do, drive it around for a week and try some roads that aren't billiard table smooth. If that's acceptable go get aligned. If it isn't raise it back up some and try again, that way you won't pay for two or three alignments in trying to get the ride height right. For best performance the car should be no lower than 3/4 of an inch from the stock height. And yes I realize that doesn't look as cool as slammed, but the car works better with suspension than it does without it. There's a thread in the tech sticky on how to lower your car the right way, before you go twisting screws, take a look and do yourself a favor.
If you really like the slammed look, spend the money for a set of coilovers and don't screw around with lowering bolts. If you can't spring for the coilovers, you shouldn't be lowering it that much.
If it rides any rougher that it did before you lowered it, you are on the bump stops. The bump stops on these cars are progressive. It doesn't hit as suddenly as conventional bump stops, so lots of folks don't realize they are on them. But if you've noticed it is stiffer, what is causing that is riding on the bump stops..
And some folks report that the car "handles great". Well they think it does because the car is firmer and more responsive, at low cornering speeds. Try driving the car hard and you will get a nasty surprise because the tail will be all over the place.
Setups like that are for waxers, not drivers.
Or better yet, I see more panties when they try getting in and out of a lowered car haha
But... to each his own. I like the aggressive look of a slammed C5Z. I am debating on lowering mine as low as I can go. However, my C5Z isn't my DD. I drive a modded 03 Subaru WRX that's lowered on Tein lowering springs along with KYB AGX 4way Adj struts for that. So... it's different strokes for different folks.
If you can sacrifice and deal with a harsh ride and learn to deal with more of the scraping everywhere you go to have the slammed look then by all means go for it. It's no big deal.
Gmz06 you're C5Z is one of the coolest and cleanest looking silver Z's on here, regardless of what, or how that you have it lowered.
