[Z06] Lowering question zip-bolts or ?
Old Feb 19, 2013 | 06:57 PM
2003corvettez06's Avatar
2003corvettez06
Default Lowering question zip-bolts or ?
Hi. My car is lowered all the way on stock bolts and im not happy with the look. I'm running 19/20 wheels.
I have bilstein sport shock as well going in.
I have Zip-lowering bolts at home which are c6 front bolts.
My question is: I would like to get rid of wheel gap. So whats gonna lower me more in the front:
1: Cutting OEM bushings.
2: installing c6 bolts
I have been reading and searching for weeks and looks like removing front bolts completely would give me slammed look which i like but im afraid to damage my leaf spring.
heres few pic of my car the way it sits now and zip-bolts
My goal is to be lowered like this.
Old Feb 20, 2013 | 05:03 AM
2003corvettez06
Bump
Old Feb 20, 2013 | 03:25 PM
tlove32's Avatar
tlove32
I have the same goal in terms of lowered stance.....I'm saving up and going the coilover route
Old Feb 20, 2013 | 03:36 PM
2003corvettez06
coilovers are the way to go but i'm not ready to spend 3,000 at the moment.
pfadt coilovers - 2200$
duties crossing to Canada - 260
install - 400
alignment - 120
Old Feb 20, 2013 | 04:01 PM
Vert'd Z0's Avatar
Vert'd Z0
2003corvettez06,
i'm with you on not being ready to pull the trigger on coilovers (hopefully soon, tho).
i see a lot of c5's (z0 or std) that have tried everything to lower their cars including removing the front bolts.
my front bolts are turned all the way up and the rear bolts are factory with one "section/slice" of the bushing cut away. i originally had the lowered bolt kit in the rear and when i put the 20's on it, they were just a little too close for my comfort. there seems to be a 1/2" "gap" between the lowered bolt kits raised up to their limit and the factory setup dropped all the way that i couldn't get to unless i cut that one section off.
i've also made my own side splitters and added a corvette creationz C5R front splitter to help protect my paint and to give it a more hammered look.
so until i can save the scratch to get some Pfadts or LG's this is going to have to do:
good luck to you and nice looking car with those new Ruff wheels.
rich
Old Feb 20, 2013 | 04:12 PM
2003corvettez06
Thank you for taking ur time to help me out here
few questions:
1: ur running 19/20 or 20/20?
2: ur running stock front bolts now or?
3: post more pic if u could plz
btw ur stance is dead on i like it car looks amazing
Originally Posted by Vert'd Z0
2003corvettez06,
rich
Old Feb 21, 2013 | 06:04 PM
Gmzo6's Avatar
Gmzo6
take the front bolt out and put a longer bolt like the zip lowering kit in the rear. It will be as low as you want it then. It won't damage the spring or control arm without the bolt. I have about 4 years on mine now and no damage. The problem going low like this isn't damage to the car, it's that you'll be pretty close to riding on the bump stop in the shock when you go this low. The only solution is coilovers.
Old Feb 22, 2013 | 07:33 AM
Sik Six's Avatar
Sik Six
I removed the front bolts completely. I did put a very thin piece of very strong rubber to protect the leaf spring. I check it every 6 months or so and it has stayed in place and not worn all the way through. The back is on a lowering bolt. I may go a little lower in back as I have a lot more room to lower it on the bolt. It looks better when on a level surface. These C5's are weird. Some will lower very low on stock bolts and others won't go very low at all. They are all different. My C6Z will go as low as I want it.
Old Feb 22, 2013 | 07:43 AM
Gmzo6's Avatar
Gmzo6
Yeah yours sits perfect. These cars are weird. I've noticed when I pull in my driveway and park it, the car will sit all crooked and has a different gap at every corner. But when you park it on a level surface the gap is the same all around. I think it has something to do with the springs cross talking and seems like it will lift the car on one side and be really low on the other when you bind the suspension up like going over a curb into a driveway.
Gmzo6's Avatar
Gmzo6
I def need to black out my taillights and reverse lights. What did u use ?
Old Feb 22, 2013 | 10:18 AM
2003corvettez06
http://forums.corvetteforum.com/c5-z...hipping-6.html
there are pic of my car POST #114
they have 2 versions.
Old Feb 22, 2013 | 10:24 AM
2003corvettez06
did u use someting like polyurethane?
Old Feb 22, 2013 | 05:40 PM
Sik Six's Avatar
Sik Six
No, mine are just the acrylic black outs. Not the best but look decent.
Old Feb 22, 2013 | 09:36 PM
GenerationX1's Avatar
GenerationX1
Sik Six what rear long bolts are you using? Looks good!!
Old Feb 23, 2013 | 07:36 AM
Sik Six's Avatar
Sik Six
I just ordered the lowering kit from Zip Corvettes. I think it was around $40. Thank u!
Old Feb 23, 2013 | 11:34 AM
02blackLS6's Avatar
02blackLS6
2003corvettez06 - The slammed cars in the pictures you posted most likely removed the front bolts or are on coilovers. However, you're car already looks lower than most lowered on factory bolts...and almost as low as mine on C6 bolts up front (i think the C6 bolts are the same as the Zip bolts). You got lucky! I wish mine sat that low on factory bolts. If you don't mind me asking, how many miles are on your Z? I'm curious to see if higher mileage cars sit noticeably lower...
If your car is that low now on factory bolts, I think the Zip bolts will get you very close to your goal. The other thing you have helping you is the 19-20" wheel combo. I already think you're front will look lower than other cars running 17 or 18" wheels up front.
C6 Front Lowering Bolt compared to Factory C5Z front bolt (pretty significant difference - meaning you still have a lot of adjustment to lower your car...considering it already appears to sit lower than others).
Old Feb 23, 2013 | 11:41 AM
2003corvettez06
thanks guys
car only has 36miles or 58km
To Lowering question zip-bolts or ?
Old Feb 23, 2013 | 11:53 AM
02blackLS6's Avatar
02blackLS6
Nice and low mileage I guess some cars just sit noticeably lower/higher than others ...lucky!
Old Feb 23, 2013 | 09:28 PM
Roc87's Avatar
Roc87
I lowered mine a few weeks ago, but I haven't got any pictures yet. From the pictures I've seen, some that are lowered on stock bolts look lower than some I've seen that are lowered on the zip/c6 bolts. I wanted the front of mine right at 26" at the fender (yeah I know that's not the proper place to measure) and with the zip bolts it and new 265/40/17's it's at 26 1/4". With the zip bolts in the rear and 2 threads showing, it was too low compared to the front, plus the 305/35/18's looked like they would have rubbed on a good bump. Now I have them adjusted so the rear fender is at 27 1/4". Its been around 200 miles and I still need to take it in for an alignment.
Old Feb 24, 2013 | 11:38 AM
Gmzo6's Avatar
Gmzo6
This is no bolts in the front and zip bolts in the rear
