BSM Nightmare
Old Mar 13, 2013 | 01:13 PM
James2002z06's Avatar
James2002z06
Default Yep
Originally Posted by dblerman
Hmm.. I find it odd that only half the door would be faded. Are you the original owner? Does a carfax show any front end body work? Sounds almost like the fender may have been replaced and when they blended into the door they sprayed over the BSM. The blend wouldn't be noticeable until you saw the hard line with the BSM removed. Just a thought.
Old Mar 13, 2013 | 01:24 PM
Aerovette's Avatar
Aerovette
I have an opposing theory. A few stated that the front was damaged and painted possibly with the BSM in place. I am of the opinion that the REAR of the door was painted and blended in approaching the front. The reason being, if the front was damaged, a new fender would not have the BSM on it at all and would be painted before putting it on OR if they did a hack job, there would be NO paint under it. If the fender was not replaced, I would expect the entire fender would be painted without the BSM on the fender UT possibly still on the door. I think the repair was toward the back and the blend was done with clear, over the BSM moving toward the front of the car.
I am no paint expert, but my experience is that clear will darken the color.
Old Mar 13, 2013 | 02:12 PM
knewblewkorvette's Avatar
knewblewkorvette
Originally Posted by Cybermind
This is the exact reason I'm hesitating in doing mine. Mine is silver like yours.
There is another post regarding BSM removal and those guys have inspired me to try it. But, now I read yours and..........I'm back on the fence.
I just need to ask; Are you sure that your car was never repainted at some point in its life?
Someone will correct me if I'm wrong but yes, I do believe that paint fade can go either way depending on the color and type. Whites will darken and blacks will lighten.
Old Mar 13, 2013 | 02:21 PM
dblerman's Avatar
dblerman
If a blend was done from the rear forward with the BSM still on the door, the rear part under the BSM would be the different color. Also, to do it properly, you wouldn't blend clear, you would respray the entire panel with clear.
My guess is the painter was lazy and didn't feel like taking the time to remove the BSM to blend the door and BSM separately.
Either way, the only fix would be to remove the BSM and repaint.
Old Mar 13, 2013 | 03:02 PM
RMB97LS1's Avatar
RMB97LS1
Should have left 'em on.. I guess you never would have known if you didn't at least try though.
Old Mar 13, 2013 | 03:10 PM
Sidewayz6.0's Avatar
Sidewayz6.0
Thats crazy. I hate hacks.
Pull the one on the other side, see if it's the same. Maybe it was just that door that was painted. If thats the case, it's not that big of deal.
Old Mar 13, 2013 | 05:03 PM
zagger's Avatar
zagger
Waxes and sealants will yellow over time if you allow lots of layers to build up one on top of another. I happen to disagree with all that say it has been re sprayed. A body shop would have painted the fender and molding at the same time but as separate pieces. If they prepped the panel and applied molding to it and painted it there would be no paint there once the molding was removed. Dirt, wax build up and UV will discolor clear coat over time, sometime a good cleaning like Dawn-clay bar-rubbing compound/wax will restore the old color. I have seen guys that removed very old stripes with same issues, if it's real bad than color sanding and re spray with clear coat does the job 95% of the time. Just my .02, good luck and in worst case scenario BSM don't look so bad.
Old Mar 13, 2013 | 05:13 PM
bj1k's Avatar
bj1k
Old Mar 13, 2013 | 05:33 PM
Aerovette's Avatar
Aerovette
I was thinking door repair with no BSM at the time but BSM still attached to the front fender.
Old Mar 13, 2013 | 06:41 PM
dblerman's Avatar
dblerman
Again, it would be odd for the waxes and sealants to only have built up on the front 1/3 of the door.
A body shop SHOULD HAVE sprayed the fender/door/BSM as separate pieces....but that doesn't mean that they did.
IF the BSM was removed from the door before it was blended, then it wouldn't be a different color under the BSM when the OP removed it, since it would have been blended UNDER the BSM
Old Mar 13, 2013 | 09:06 PM
Aerovette's Avatar
Aerovette
I'm an idiot. I know where I went off track. No use even trying to explain. My brain farted.
Old Mar 13, 2013 | 09:37 PM
dblerman's Avatar
dblerman
haha no worries. You just weren't thinking 4th dimensionally
Old Mar 13, 2013 | 09:42 PM
  #33
3boystoys's Avatar
3boystoys
Originally Posted by SilverBullet95
I'm afraid this may be the case. Still trying to decide if it is worth the $$ to repaint, or if I should just give in and reapply the BSM
No question this is the case. BSM's look better anyway.
Old Mar 13, 2013 | 10:02 PM
  #34
Brackneyc's Avatar
Brackneyc
Took mine off my 98 the first week I had it (bought in 2012), no issues at all. I'd have the doors repainted before I ever put those dime store add-ons back on my Vette.
Old Mar 13, 2013 | 10:07 PM
  #35
meflyfrc's Avatar
meflyfrc
I've only had the car since early January, and since I got it at auction I wasn't able to get any info on the previous owner. After looking into it, I think I'll probably just get the paint blended and leave the BSM's off. I cant stand the look of BSM's
That's what I would do. If you put the BSMs back on you're just going to know whats underneath and it will probably bother the hell out of ya, I know it would me.
Old Jul 27, 2013 | 01:37 AM
  #36
TorqueJunkie's Avatar
TorqueJunkie
What did you end up doing? I am contemplating removing the BSMs on my Silver '04.
Old Jul 27, 2013 | 01:54 AM
  #37
damilleniumboy's Avatar
damilleniumboy
Travis
Let it sit on the sun for a day or two; I used to have a zinc yellow Mustang, and I had two 10" stripes on it. When I took them off, the yellow under the stripes was a bit off a different color. After it sat on the sun for a day or two, it blended. I don't know how to explain it better. The door does however look like it was re-cleared; I might be wrong.
