Installed the lmc5!
Old May 20, 2013 | 11:46 PM
  #61
red03vette's Avatar
red03vette
Originally Posted by Baldfart
I had originally bought the CLB, but I had not installed it and did a lot of reading regarding the LMC5. I bought the LMC5 and installed it and so far love it. They are both good products but IMHO the LMC5 edges out the CLB.
Sounds good! And thanks I need all the help I can get!
Old May 20, 2013 | 11:52 PM
  #62
_zebra's Avatar
_zebra
you only need the unlocker with the LMC5 if the column won't unlock by itself. if you're buying the bypass, i don't understand why you wouldn't go ahead install it before the lock screws up, but that's just me. mine worked every time, but i went ahead and put in the LMC5 so i ain't got to worry about it later - that & i got tired of leaving my keys in the ignition everywhere.
Old May 20, 2013 | 11:58 PM
  #63
red03vette's Avatar
red03vette
Originally Posted by 8VETTE7
Answer this question to your self:
Does your cars column lock with NO KEY in the ignition????
If you answered YES, then 2 items to consider:
1) If your NOT going to install the product immediately then what would you do if the column lock symptoms occur and the failure is with the column locked????????
2) If you are going to install it immediately, how are you going to get the column unlocked???? An unlocked column is a requirement to be able to install either a CLB or an LMC5.
If you answered NO then you don't need the unlocker.
There are other ways to unlock the column to be able to install either after market product just as an FYI.
Ok just ran out to the shop to check, YES the column does indeed lock with "no key in ignition"!
1) ok gotcha!
2) ah ha! Now I understand! Thanks
After having a quick look just now I get it. Sometimes I just need a little extra "splainin"
Old May 21, 2013 | 12:06 AM
  #64
red03vette's Avatar
red03vette
Originally Posted by Suthunman
To install the LMC5, the first step will be to disconnect the battery. Your column will be locked at that time. You will need the unlocker to unlock the column lock during the installation. I really don't know why they don't include the unlocker with the LMC5. There are ways around it but the installation instructions only tell you how to unlock it with the unlocker.
Right, thank you. when I order I will get the unlocker too!
Old May 21, 2013 | 12:15 AM
  #65
red03vette's Avatar
red03vette
Say what? Just when I thought I had a handle on this, I "don't" need the unlocker? Right now the lock works and I have not had a problem, so I was going to install this part before any problems arise! I don't want to be out during the driving season and have any problems if I'm along ways from home base.
Old May 21, 2013 | 12:52 AM
  #66
Suthunman's Avatar
Suthunman
St. Jude Donor '14
It costs $6. You will be glad you got it.
Old May 21, 2013 | 01:00 AM
  #67
red03vette's Avatar
red03vette
Old May 21, 2013 | 01:08 AM
  #68
_zebra's Avatar
_zebra
for a properly-functioning column lock, you can buy the extra unlocker cable if you want, but it's unnecessary. i'm glad i ain't gone one more part just sitting around taking up space.
straight from the installation guide:
If your column unlocks when you turn the key to ON, you may try this alternate column unlock procedure BEFORE beginning the LMC5 installation: Turn the key to ON, then remove fuse 23 in the passenger footwell fuse panel. Remove the key and verify the steering wheel remains unlocked (repeatedly turn and also tilt the steering wheel). Proceed to the LMC5 installation, and replace fuse 23 after completing Step 1.
Old May 21, 2013 | 01:16 AM
  #69
red03vette's Avatar
red03vette
Wow! Thanks! And this is why this forum rocks thanks for all the help zebra! And everyone else!
Old Jun 3, 2013 | 01:08 PM
  #70
sb70ss's Avatar
sb70ss
Cruising
Default LMC5 Installed
Installed mine over the weekend and worked fine.
My 2000 Auto already had the the recall years back so did not have to unlock it.
Instructions were very clear and easy. Just be patient when switching the wires in plug.
Prior to install I was getting both error messages and now they have dissapeared.
I highly recommend this product!
Old Jun 3, 2013 | 03:14 PM
  #71
red03vette's Avatar
red03vette
sweet! going to order mine right away.
