[Z06] Z06 Quality Issues
Old Jun 20, 2002 | 06:09 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Default [POLL] Z06 Quality Issues
I was curious to hear about how the Z06 has treated you guys. Have you guys had to take your cars back to the dealer for any service?
--rb--
02 Z06
[Modified by rbartick, 4:10 PM 6/20/2002]
Old Jun 20, 2002 | 06:24 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Default Re: [POLL] Z06 Quality Issues (rbartick)
I may not be all that picky - I am impressed that they were able to put such a car in my hands -
Absolutely perfect? no
Acceptable? You bet.
If I found out that Britney Spears had a pimple on her butt, I would still take her out to dinner.
best regards -
mqqn
Old Jun 20, 2002 | 06:37 PM
edwards's Avatar
edwards
Default Re: [POLL] Z06 Quality Issues (mqqn)
Old Jun 20, 2002 | 07:07 PM
Rebelskum's Avatar
Rebelskum
I'm the one who voted for multiple trips to the dealership. 5 trips to be exact. 4 for the same problem.
They replaced almost everything (New PCM, 2 Fuel Pumps and sending unit, a starter, after they accidentally broke it) to stop the engine light from coming on and the occasional engine misfire. Fourth time I took it in, I gave them some more info I got from the forum. This time they found the culprit. The wiring harness connecting the fuel injector which feeds the #7 Cylinder was frayed and hitting the engine block.
So, I wouldn't say it was Chevy's fault, or poor build quality. It was the service dept. at my local dealership that caused me to go in so many times.
Glad I am moving a bit farther north so that if I have any future issues, I can take it to the dealership I'm used to and can trust a little more than this one.
Only build quality issue I had to take the car in for thus far was the wiring harness under the center console was crimped when installed at the factory.
Sorry for the length, been holding that in for a while... *whew*
Old Jun 20, 2002 | 08:42 PM
phrogs's Avatar
phrogs
Veteran: Marine Corps
:yesnod: huh!!!!!
Old Jun 20, 2002 | 09:26 PM
z06dailydriver's Avatar
z06dailydriver
Default Re: [POLL] Z06 Quality Issues (phrogs)
I too had a sending unit/fuel pump replaced at5k miles. Bad fuel readings . Other than that never been back. the exhuast rings like jingle bells but with the a/c on all the time I'll wait till the fall to do something about it. Considering the power and its strain on the car, its holding up well.
Old Jun 20, 2002 | 11:30 PM
MikeFleischer's Avatar
MikeFleischer
Default Re: [POLL] Z06 Quality Issues (z06dailydriver)
I just had the sending unit replaced on my Z06. Along with the MAF which was misreading and making the car run too rich (= less power).
Also it goes in Monday for new rings... Burns oil at an alarming rate now.
Oh then there was the throttle position sensor that went bad (replaced it)
And the O2 sensor that triggered a fault (replaced)
And the charge faults it kept getting (replaced the battery)
All little problems. Like being nibbled to death by hamsters.
At least when it goes it really really goes...
Count me as #2 with multiple problems.
Old Jun 21, 2002 | 10:51 AM
stingray454's Avatar
stingray454
I brought my car in to the dealer for service for a few minor things:
- Wind noise above 60MPH near the rear part of where the driver's window meets the door. They 'adjusted' the window alignment, which fixed the problem on the ride back from the dealer, but now the wind has re-appeared. Looking closely now at the weatherstripping, it looks like theres a chunk of rubber missing from the door weatherstripping, like it was a manufacturing defect. Incidentally the weatherstripping is by far the worst I have ever seen on a car and is the only quality issue I've noticed. There's glue all over the place, uneven in some places, and the quality of the weatherstipping material looks really weak. Very sloppy job. BG needs to fire the weather stripping installer, IMO.
- I've heard an intermittent clacking/ticking sound from the engine that is louder than I've heard on any other Z06. Almost definitely a noisey lifter problem. Dealer says they couldn't hear anything abnormal from the engine :rolleyes: I was going to suggest they get their ears checked, but instead I decided to just let it be. At least I had it checked out - if the engine fails later under warranty, that's GM's problem, not mine. I've done my fair share by having it checked by the dealer.
- Exhaust jingle very annoying. I knew this was a 'normal' problem thanks to the forum and that there is no dealer fix for it, but I decided to let the dealer check it out anyway in the remote chance they could fix it. The dealer came back after trying to find the source (which they couldn't) and said it was a 'normal Z06 noise - cannot change - no known fix).
Next time I bring it in, I will have them replace the driver's door weatherstripping.
Overall though, I'm still pleased with the quality of the Z06. Just one minor quality issue/defect isn't bad for such a complex machine, IMO.
Old Jun 21, 2002 | 01:30 PM
rwd's Avatar
rwd
So far, apart from a noisy fuel pump (still on the car) mine's been good. Fit and finish could be better, though.
I'm really not looking forward to taking it to a dealer.
Old Jun 21, 2002 | 01:53 PM
BIG LAW MAN's Avatar
BIG LAW MAN
Well, other than the annoying exhaust jingle that "I" will be fixing, I have had no problems in 1500 miles so far! :D
Old Jun 21, 2002 | 02:44 PM
ragvette's Avatar
ragvette
No problems so far @ 1,000 miles. Only went back to the dealer for an oil change.
Old Jun 21, 2002 | 03:46 PM
B-Myster's Avatar
B-Myster
Well my first 02 Z06 needed a new engine at 695 miles, but GM bought it back so I guess I'll let that one slide. :jester
My 2nd 02 Z06 is problem-free so far at 1300 miles. :cheers:
Old Jun 22, 2002 | 06:41 PM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
I've had several propblems. 1 caused by the dealer and 3 by GM.
First the GM problems. My car came from the factory with the sticky brake booster issue. Dealer fixed it right the first time. After about a year the differential started leaking at the axle on the driver's side. Again the dealer fixed it right the first time. The car also came from the factory with the finish on the molding around the driver's side window peeling. Dealer fixed it right.
Now for the one that still burns me. When unloading the car off the truck, apparently, the front of the car was dropped. It cracked the rocker panels and damaged the driver's side front fender. Repairs were made, but after removing the BSM's you could see where they made the repair in a half a%$ manner. It's still visible today to the trained eye.
Oh yeah, I almost forgot the oil burning problem which I'm going to have fixed some time this summer (which does scare the %^$* out of me).
This is my 4th C5 and is without a doubt the worst quality of any of them. Having said all this though, I still love the car and plan on keeping it a long time.
Old Jun 25, 2002 | 11:34 AM
dbvettez06's Avatar
dbvettez06
Default Re: [POLL] Z06 Quality Issues (CorvetteSS)
GM built a great car this time....My only complaint was not enough HP, but i fixed that :lol:
Old Jun 25, 2002 | 04:23 PM
Lawdogg's Avatar
Lawdogg
Active Streak: 90 Days
Default Re: [POLL] Z06 Quality Issues (dbvettez06)
The only warranty matter in 23,000 miles was a new tranny when the car was days old. I chalked that one up to mine being built the second day of Z06 production. Chevy overnighted a tranny and my total down time was 24 hours. :yesnod: :chevy My car is driven hard and tracked often and, so far, it is bullet proof (even the original stock clutch). :eek:
Old Jun 25, 2002 | 06:38 PM
CALVette's Avatar
CALVette
Cruise-In V Veteran
Almost 12,000 mile and has not been in for anything yet. I change my own oil.
Old Jun 26, 2002 | 02:58 PM
shredder 44's Avatar
shredder 44
6th Gear
Default Re: [POLL] Z06 Quality Issues (BIG LAW MAN)
Big Law Man,
How do you fix that exhaust jingle??
To Z06 Quality Issues
Old Jun 26, 2002 | 08:28 PM
GalaxyEng's Avatar
GalaxyEng
Other than the engine disintegrating at 480 babied miles, I have had no problems at all. :smash:
Old Jun 26, 2002 | 10:00 PM
stingray454
Default Re: [POLL] Z06 Quality Issues (GalaxyEng)
Could you please elaborate as to what happened to your engine?
:confused:
Old Jun 27, 2002 | 02:36 PM
MikeFleischer
Yeah please elaborate...
I took my car in Monday for new rings and am told the motor is shot and they are replacing it (9400 miles). It was burning 1 qt about every 200 miles.
How did they do replacing it? Any problems with the new motor? Any issues? I am a little bit on the edge of scared that its gonna get back to me and have all kinds of "forgot to hook that up" and "oops, left that out" problems...
