[Z06] big brake setup
Old May 15, 2013 | 07:43 AM
Gmzo6's Avatar
Gmzo6
Default big brake setup
Hey guys, my father is a tech for gm and I wanted to get a price on the parts for the big brake setup. Does anyone know what all I need to run this? I have a 2001 zo6. Thanks
Old May 17, 2013 | 06:50 PM
MotoJB's Avatar
MotoJB
C6Z Big Brakes? Calipers, rotors, lines & fluid kits are to be had all packaged and bundled...ready to go. Google or searching here will find you what you need.
Old May 17, 2013 | 07:07 PM
SJSZ06's Avatar
SJSZ06
Yes, but don't forget the larger wheels and tires...
Old May 18, 2013 | 12:32 PM
robert miller's Avatar
robert miller
Old May 18, 2013 | 08:05 PM
C5Conrad's Avatar
C5Conrad
Will 2010+ Camaro SS brembo 4 piston brakes bolt on also? Rather than stepping up to the more expensive C6 Z06 brakes.
Old May 18, 2013 | 11:02 PM
Gmzo6's Avatar
Gmzo6
Good question.
Old May 19, 2013 | 02:36 PM
AU N EGL's Avatar
AU N EGL
if your going to spend the money for BBK, Stoptech T60 / T40 APRacing T1 set up, Brembo GT 6/4 pots.
Or at THE Wilwood set up that will fit under the stock wheels.
To big brake setup
