AC vacuum line help!
Old May 18, 2013 | 08:45 PM
C5 Corvette C5's Avatar
C5 Corvette C5
Default AC vacuum line help!
I just repaired the leaking battery acid. Took the fender off, grinded the frame to bare metal, painted everything looks great. Now im repairing the broken AC vacuum lines from the leaking battery. Both were broken so I peased in some vacuum line. Started the car the vents were still not switching modes.
Then I hooked a vacuum gauge to each line (manifold/one going to the car). Started the car the gauge didn't move for ether of the lines. So does this mean that the vacuum line to the manifold is broken somewhere?
Thank you for your help.
Old May 19, 2013 | 12:55 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Here is a write-up I did for this fix
http://forums.corvetteforum.com/c5-t...with-pics.html
Thanks,Matt
Old May 19, 2013 | 02:28 PM
C5 Corvette C5
Got it fixed! It was the vacuum line from the mainfold. I replaced the whole line. The AC feals great!
To AC vacuum line help!
