Hub paint
Old May 31, 2013 | 03:26 PM
chasboy's Avatar
chasboy
Oldtimer
Default Hub paint
Anyone here paint their rotor hubs while the wheel is off? Mine are 'ok' but I would like to spruce them up. I have a Black Z with the painted wheels. I don't want red, and I'm not sure I want those covers either. Thanks!
Old May 31, 2013 | 03:55 PM
3boystoys's Avatar
3boystoys
Used silver on mine.
Old May 31, 2013 | 04:44 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Silver or black would work well.
Old May 31, 2013 | 04:49 PM
NSTG8R's Avatar
NSTG8R
+1 black.
Just try and aim for the hub of the rotor. I did this once with disregard to how much of the rotor I covered .. needless to say, I had a bunch of paint in my pads that needed cleaning off.
Old May 31, 2013 | 04:54 PM
Corvette_Ed's Avatar
Corvette_Ed
Has anyone painted zinc-coated rotors?
Old May 31, 2013 | 05:05 PM
Zr-1Mike00's Avatar
Zr-1Mike00
I need to spruce mine up as well. Mine look
Old May 31, 2013 | 05:16 PM
paldogy's Avatar
paldogy
mine were rusty and i sprayed with a rust coverter, available at boat us or other marine store, it turns them black and kills the rust. Then painted with gray rustoleum hamertone and they have looked like new for two years now.
Old May 31, 2013 | 05:29 PM
Zr-1Mike00's Avatar
Zr-1Mike00
This stuff? If so it is also available at Ace Hardware for $5.99. I have one here in town that if this is the stuff I'm gonna give it a try!!
Old May 31, 2013 | 07:02 PM
chasboy's Avatar
chasboy
Oldtimer
Originally Posted by NSTG8R
+1 black.
I made the same, but worse mistake on another car and had to replace the pads. Did anyone brush other than spray? I've used hammertone many times and it comes out great.
Old May 31, 2013 | 08:19 PM
crazystevex's Avatar
crazystevex
Use VHT brake caliper paint, from the parts store that stuff works great and its tough
Old May 31, 2013 | 08:36 PM
A good tape job around the pad path and some caliper paint will do the trick. I did my stock calipers that way.
Old May 31, 2013 | 11:05 PM
rx4arx's Avatar
rx4arx
Did mine this way.
Pull the wheel. Clean the surface of the hub area with brake cleaner. Then clean with Methyl Alcohol. Mask the entire rotor surface with masking tape. Get your box cutter or scalpel type knife. Spin the rotor observing where the brake pad passes over the masking. Place the knife blade against the closest part (to the hub) of the caliper or pad. Press it into the masked tape. Spin the wheel. Cuts a perfect circle. Peel the inside leaving the outer tape on the rotor. Now spray with VHT caliper paint. I used black.
Old May 31, 2013 | 11:17 PM
chasboy's Avatar
chasboy
Oldtimer
How well does the hammertone show thru the wheel spokes?
Old May 31, 2013 | 11:21 PM
chasboy's Avatar
chasboy
Oldtimer
Originally Posted by rx4arx
Did mine this way.
THAT is a great idea! I'm assuming the tape clears the distance between the pad and rotor?
Old May 31, 2013 | 11:49 PM
rx4arx's Avatar
rx4arx
You know I was doing some work on the brakes at the same time.
I may have had the pads out of the calipers at the time. Can't truly recall. Masking tape is fairly thin - I think it would work either way.
Old Jun 5, 2013 | 12:05 AM
paldogy's Avatar
paldogy
it is actually a rust converter, repeat converter, it kills the rust and turns it black so you don't have to sandpaper, Just paint over it.
Available at West Marine
Old Jun 5, 2013 | 02:11 AM
yaknow's Avatar
yaknow
i know it sounds crude, but painted mine with rustoluem paint and a sponge brush 4 years and still holding strong
To Hub paint
