Replacing speakers
Old Jun 2, 2013 | 02:30 PM
flags97's Avatar
flags97
Default Replacing speakers
I am replacing speakers, the back ones I know just pry off the grill but the front ones, I am changing the 3.5 not the woofer, is only access is to take off the door panel or can they be ptired off like the back speakers.Thanks
Old Jun 2, 2013 | 02:35 PM
LoneStarFRC's Avatar
LoneStarFRC
Remove door panel. Do NOT attempt to "pry off" the grills. When you get the panel off you will see why.
HTH
Old Jun 2, 2013 | 02:39 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
HTH
Old Jun 2, 2013 | 02:44 PM
flags97's Avatar
flags97
HTH
Thanks, I thought that, understand two screws behind door pull and then just pop out, do you know how many contacts that I need to pop the panel from....Thanks
Old Jun 2, 2013 | 05:53 PM
LoneStarFRC
understand two screws behind door pull and then just pop out.........,
Wrong. You must also carefully release the door handle trim ring. There are 4 tabs and you WILL break one if you get too hamfisted. A small flat blade and some judicious prying and you should get it off. Take your time.
........do you know how many contacts that I need to pop the panel from....Thanks
If by "contacts" you mean retaining pins, I don't recall the exact number, though IIRC I would say about 5, maybe 6 per door. They are white plastic pins and the "male" portion is attached to the door panel and the "female" receptacles are attached to the door itself. Use a small non-marring tool like a putty knife (with tape over the blade) and start at the bottom rear corner. With your fingers try to pry open far enough to get your fingers into the crack and SHARPLY yank the door panel away from the door a short distance. Once free, lift up panel first (about 1/2" or so) then off the door. Note: the male pins can easily break so be careful with them, especially when re-attaching the door panel.
Old Jun 2, 2013 | 06:07 PM
flags97's Avatar
flags97
Default Thanks Lonestar
Will be doing this job next weekend, thanks for the instructions!!!
Old Jun 2, 2013 | 06:17 PM
LoneStarFRC
It would be wise to get an extra couple male pins beforehand. The newer (later) versions have a rubber cushion ring on them. They are a better design. The "head" just twists into a slot on the door panel.
Go to the auction site and/or Google C5 Corvette door pins. Did I mention they break easily?
Old Jun 2, 2013 | 06:36 PM
Chicago1's Avatar
Chicago1
Ahhhh pulling the door panel another job involving lots of cussing. Buy a door panel puller at harbor freight or somewhere you will thank me later
Old Jun 2, 2013 | 06:49 PM
flags97's Avatar
flags97
Default Door panel removal
Well I just took off the drivers side door panel, it was to easy so I am having some doubts if the previous owner did something to it!! I removed the tab behind the handle and the tab came right out but it has a bunch of sticky substance(like glue) is this normal? I removed the two screws than slowly undid the pins. Came off just fine, but the clip to wires to the door I could not unplug. But still have enough room to remove speaker and replace. Anyway, do any of you guys have this glue substance on tab behind the handle?
Old Jun 2, 2013 | 07:07 PM
racebum's Avatar
racebum
make sure you look at the polarity of the speakers you install. the bose uses + as the small terminal and every aftermarket has - as the small side.
you typically have to cut the factory spade connectors and solder the wires to your new speakers.
if you just hook them up as they fit your 3.5's will be 180 out of phase
also worth buying some protecto wrap at home depot and or dynamat for the install. the aftermarket 3.5s line up but don't seal the flange very well. a little sticky tar wrap fixes any rattles and gives you a nice seal.
i also used dynamat on my door pannels and it really cut down the bass rattles
Old Jun 2, 2013 | 07:10 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Get a tool that helps you pry off the tabs or you'll break some. Even so I second getting some extras because you will most likely break some or find some broken. It's also very easy to break the plastic on the door panel that holds the tabs.
flags97's Avatar
flags97
I ordered the speakers from DoubleDMods so should hook up correctly with the adaptors from Double D, wrap sounds like a great idea, will do!!!
Old Jun 2, 2013 | 07:15 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
No, there shouldn't be any glue substance there. Those pieces have 5 small tabs on them to hold them in place that routinely break off. I'd bet the previous owner used some sort of glue to hold them in place after the tabs broke off. The part is relatively cheap but plan on it breaking again in the future.
Old Jun 2, 2013 | 07:18 PM
RetiredSFC 97
This is correct. My tabs are broken and I use silicone to hold it in place.
flags97's Avatar
flags97
Thanks,mine had 4 tabs on it, must have broke in the past, do you know what they are called and where can I order some?
Old Jun 2, 2013 | 07:26 PM
LoneStarFRC
...... Anyway, do any of you guys have this glue substance on tab behind the handle?
Glue/adhesive not original. Sounds like broken tab and glued on.
Double-sided tape works better. The tabs on those break easily. Even if I was putting an unbroken one back on, I would still use double-sided tape on the backside. If unbroken, there should be 7 tabs total on the back.
Oh, btw. To pop out the driver's window switch panel, use a small flat blade under the bottom (rearward) edge and pry up, then pull switch rearward and then out. The front edge "hooks" in.
On the passenger door, pry up from the top edge first.
Old Jun 2, 2013 | 07:28 PM
RetiredSFC 97
Here
I just ordered some for 14 bucks and now I find these
Mid America Motorworks also has them but they cost more
I'll pm you.
To Replacing speakers
Old Jun 2, 2013 | 07:31 PM
LoneStarFRC
.........do you know what they are called and where can I order some?
Google C5 door panel access plugs. Shop around. Some places like to try to rape you. Usually in the $3 - $4 (~) range is typical.
gmpartseastdotcom has them for $2.60 ea 10279471
Old Jun 2, 2013 | 07:34 PM
LoneStarFRC
Originally Posted by RetiredSFC 97
Here
Holy cow! Did at least give you a big wet kiss when they were through with you.
Old Jun 2, 2013 | 07:39 PM
RetiredSFC 97
one cost almost 12 bucks with shipping and handling there. I would ebay route 11 bucks for two with shipping.
Do what you want, good luck
