2000 vert...electrical problems
Old Jun 3, 2013 | 05:08 PM
echelonphoto's Avatar
echelonphoto
Default 2000 vert...electrical problems
Seems I've got a short somewhere. Today, I had problem with all my
drivers side window and lock controls...then as I was driving...I got various messages like .....reduced engine power....service engine soon,
then all gauges would not work and radio also turned off. Car ran ok.
I stopped at a light and turned it on and off again and the messages cleared, but thirty seconds later came back again. I should note ..It was raining hard.
Old Jun 3, 2013 | 09:09 PM
CPhelps's Avatar
CPhelps
Scan your codes and post them:
Turn ignition to on.
Hold the options button and hit fuel button four times.
This will enter the diagnostic mode and it will scroll through the codes (by module) that have been set. Codes that have an H behind them are "history", codes with C are current. Post up the codes you get and we can help you out.
Old Jun 3, 2013 | 10:34 PM
DaDuck's Avatar
DaDuck
I would check for loose battery terminals.
Clean the ground connectors under the hood.
Have the battery/alternator tested.
Sounds like too many symptoms to diagnose with the DIC.
Old Jun 4, 2013 | 09:39 AM
3boystoys's Avatar
3boystoys
Probably the connections in the accordion tube from the doors. Do an Advanced search on "Accordion"
Old Jun 4, 2013 | 11:23 AM
kpcets's Avatar
kpcets
Veteran: National Guard
I would also make sure the drain (udders) for the wipers are not clogged, which could cause a water back up.
Old Jun 4, 2013 | 01:02 PM
echelonphoto
thanks for the input....it is definitely in the door accordion. When I open the door and pull on the boot all problems temporarily disappear.
Old Jun 4, 2013 | 01:33 PM
memmer's Avatar
memmer
Love this Forum.Can you imagine what a stealership would charge to fix a problem like this
Fred
Old Jun 4, 2013 | 02:00 PM
echelonphoto
Default So far ...so good
After searching "accordion" I found several great posts with detailed
photos....I opened the accordion and found the blue connector with the
little bare wire extending out...I checked the contacts and they were ok. I wrapped the bare wire with some good electrical tape and put it back in...just drove the car and the problem seems to be corrected.
I LOVE THIS FORUM....just think where we would be without all this free, first hand advice from members who have been there...we'd be
at the dealer shelling out bocough bucks for someone who doesn't have a clue about the REAL issue and winds up replacing many random
expensive parts (according to the shop manual, which also doesn't have a clue)...only to have the problem reoccur.
I figure this forum has been worth many thousands of dollars to me over the last several years....keep posting and keep driving that vette!
To 2000 vert...electrical problems
