I want to change my shift **** on my auto trans to a plain white cue ball look. have any of you guys done this? if so where did you get the conversion kit and was it tough to do?
Not to jack this thread but does the new setup sit higher then the original shift ****?
From the install directions...
"Depending on the after market **** or ball you use will depend if it is higher than your stock ****. It will usually be
about 1/2” or a little higher. You can adjust this a little by
drilling most ***** or ***** out a little. A number of ***** like
the MOMO have a sleeve to fit into the **** so it will fit, and
then are held on by Allen set screws. We have had even better success by wrapping the shaft with electrical tape until the
thickness is achieved."
