Battery or alernator?
Old Jul 10, 2013 | 10:03 PM
Mikev9898's Avatar
Mikev9898
4th Gear
Default Battery or alernator?
Hey guys, first post. I have a 2000 c5 and i replaced the battery about a month ago because it had gone bad. Now the car will not hold a charge for more than 24hrs. I have not been driving the car much because this has been an issue. I'm leaning towards the alternator because the volts on the dash display read anywhere between 11v to 13v depending what electronics are running in the car, but i don't just want to go out and buy an alternator if that is not the problem. HELP PLEASE! Thanks
Old Jul 10, 2013 | 10:18 PM
Mikev9898's Avatar
Mikev9898
4th Gear
Thanks man ill do some testing and get back to you
Old Jul 10, 2013 | 11:45 PM
65GGvert's Avatar
65GGvert
On two occasions I have seen the variation in voltage you describe and both times it has been the red wire connection at the starter solenoid from the battery. It has been loose and corroded (looks burned). On one of those two, the starter solenoid bakelite material around the post was crystalized and the starter had to be replaced. Both these cars had headers if that makes a difference. The voltage should not drop below 12.5 volts when the car is running no matter the load. Usually they will read 13 to 14 volts. That lug is the connection point between the battery and the alternator, if it is loose or corroded, the battery will never get charge enough by the alternator.
Old Jul 11, 2013 | 01:26 AM
DeeGee's Avatar
DeeGee
This car eats batteries without regular attention so my guess would be battery.
Here's an old post of mine that may help:
Identifying Battery Problems
The C5 eats batteries unless you take some regular precautions. If your battery continually dies its either the battery which is on its last legs or something on the car.
You also need to look at how you use the car. Is it a daily driver? If so the battery should be getting a good top up every day so you may have a problem.
Is it a DD but you do short trips? If so you'll be taking a lot out of the battery every time you start. For a short trip, say less than about 20 mins, you won’t top it off properly. Eventually it'll drain.
Is it a weekend car. If so, this takes a lot out of your battery. There’s a 20MA drain even dormant. If you don’t drive the car for a reasonable time every week or so, it'll kill the battery. In this case you really do need a battery tender.
You’ll know when your battery is bad. As it gets low you may get strange electrical indications (random warnings and U fault codes). As it gets lower it may drop the memory settings or defaults such as HUD settings. Eventually you’ll get the dreaded chattering relays in the footwell and eventually the lights on the IPC will disappear.
Most batteries can be recharged quite successfully, although AGMs are harder. Start by checking the charge on the battery. Don’t read the DIC when the car is off. The value you see on the DIC is alternator output when the car is running. It will always measure an inaccurately low voltage on the battery when the ignition is off and figures of 11.0V to 11.9V is normal in this case. With the engine on, the voltmeter should show between 13V and 14.5V. You need to measure voltage across the battery terminals using a digital multi meter if possible. A fully charged battery measures 12.7V and a fully discharged battery measures 11.9V. Partially discharged batteries will give a reading somewhere in between.
If the battery is low give it an overnight charge (or put it on a battery tender until you get a fully charged indication) and retest it. A true test is under load and Autozone will do that test for free.
If you have an AGM battery like the Red Top and it has been deeply discharged it's harder to recover it. This might help:
If you’ve recharged it and it still runs down, then you need to start looking for excessive drains. Bill Curlee posted a good method for checking:
http://forums.corvetteforum.com/1567522286-post590.html
There are some common faults which are well known for causing problems:
First to check is the interior lighting rotary switch on the drivers panel. It’s possible for that to be turned on as there’s a setting (fully clockwise) which bypasses the auto off function. Turn it fully counter clockwise and check after about 30 minutes (preferably in the dark) that the interior lights have gone off.
If it’s not the lights something has failed or is badly installed.
Have you fitted an after-market device which draws current? Typically it’s a cellphone charger, radar warner or a similar device that’s the problem.
If still no joy, you need to start pulling fuses to identify the problem.
The power seat switches on the side of both seats are notoriously unreliable. The switch becomes sticky with use and can stick in the “on” position. You shouldn’t damage the motors as they are thermally protected. The fuse may blow so worth checking (Fuse 36 20A in footwell).
The driver’s lumbar motor can also cause issues so check this too (mini fuse 3 15A in footwell). The seat controls connect under the seat. Pull the connector and if the drain stops that’s your problem.
Less common but not unheard of are failures of the headlight motor control module the alternator and the Bose Amplifier under the dash on the driver’s side.
To Battery or alernator?
