New Tire Question's
Old Jul 28, 2013 | 12:30 PM
bikeriderga's Avatar
bikeriderga
The best are Michelin Pilot Super Sports. I do not like run flats, but to each his own.
Others will cost less, but you get what you pay for.
Old Jul 28, 2013 | 12:33 PM
Corvette_Ed's Avatar
Corvette_Ed
Originally Posted by Ohyoufan
Discount Tire rebuilt my TPMS sensors with new battery's in my 99 FRC when I had my Nitto 555's installed. The Nitto's replaced Kumho run-flats that rode like crap, were loud as hell, and handled like crap as well. If you drive 2,000 miles a year than I'd just get some nice performance tires.
Mine were also rebuilt by DT when I had my Nitto's installed recently.
Old Jul 28, 2013 | 06:09 PM
Originally Posted by PryOpenUr3rdEye
I have Michelin RFs, they are an upgrade over the GYRFs, but I urge you to go non-RF
Go with the Hankooks and get AAA
Michelin makes about the best runflat, but non-runflats would ride and handle much better.
Old Jul 28, 2013 | 07:00 PM
acat1234's Avatar
acat1234
Ok everyone, I know this is a well worn topic, but what is the best and most popular run- flat or non - run flat tires for a 2001 coupe? Can't decide to go with run flats or not. Do not race car and put around 2,000 miles per year but this year may send car to Florida and drive back in spring (1,300 miles). Most concerned about wet weather traction.
Thanks for your help.
Old Jul 28, 2013 | 07:37 PM
Choreo's Avatar
Choreo
I am on my 2nd set of Michelin A/S ZP Plus Run Flats and plan to buy them as my next set as well.
On a 2002, you will want a new set of sensors (less than $200).
Number of miles per year does not affect the decision on RF vs non-RF. The question is what do those miles consist of? If high-performance or lowest noise level possible is paramount and you don't mind groveling around in the dirt to find a puncture or calling AAA, then the non-RF is a no brainer.
In my case, my C5 is a DD and the additional peace of mind that a RF offers far outweighs the tradeoff in my case. I have places that I have to be on-time and don't have the desire to stop and wrestle with a flat tire with no warning. I have had at least 7 flats over the years with my C5, but I never had to stop once at the time the flat occurred. I was always able to schedule the fix a day or two later at "my" convenience. I don't generally push my car to the limits, so I am in agreement with GMs decision to spend the extra money on an RF for a street C5.
If you don't mind the possible inconvenience or don't think you will ever have a flat, then non-RF is the ticket.
Old Jul 28, 2013 | 09:11 PM
MS04Cpe's Avatar
MS04Cpe
I am very impressed with the Michelin Pilot Sport A/S 3...especially in the wet.
Wayne
Old Jul 31, 2013 | 08:43 PM
acat1234's Avatar
acat1234
Just came back from COSTCO. They priced a set of Michelin Super Sports (Non RF) mounted, Nitrogen filled, Road Hazard, etc. for $1,033 incl taxes. A set of Bridgestone Potenza RE 960 RF were $1,200 total. Replacement sensors were $45/ea installed and reset. Any opinions? My car is not a daily driver and is stored in the winter.
Old Jul 31, 2013 | 08:49 PM
VETJAZZ's Avatar
VETJAZZ
Good price for the Michelins. You can get the sensors cheaper on line, but installed and reset $45 is not bad. I don't know about the Bridgestones.
CQRT's Avatar
CQRT
or Nitto 555's . . about $750 out the door . . half the cost of runflats . . AAA's about $125/yr.
Old Jul 31, 2013 | 08:58 PM
PryOpenUr3rdEye's Avatar
PryOpenUr3rdEye
Nitrogen filled
Pass on the nitrogen and see if they come off the price any
Old Aug 1, 2013 | 02:15 AM
torchredmadness's Avatar
torchredmadness
I run Kumho Ecsta's on our car. No problems at all. We don't track the car or do full blown burn outs but we don't baby the car either. Tires have never been an issue so far. They have about 20,000 miles on them. Road noise is not a problem. Check 'em out.
Old Aug 1, 2013 | 06:49 AM
ZigZag's Avatar
ZigZag
The price for the Michelin's with the extras is very good. And the new sensors installed and reset is very fair also. The Super Sports are excellent and you can't go wrong. I have them on my 05 GTO with 570 h.p. and they are quiet and grip very well. JMO though
Old Aug 1, 2013 | 09:17 AM
  #33
Kingman99's Avatar
Kingman99
Default Nitrogen ???
Why Nitrogen? I have never used anything but air!
Old Aug 1, 2013 | 11:59 AM
  #34
GrandSportRob's Avatar
GrandSportRob
I had Goodyear Eagle GS D3's on my 99.. It's a non run flat but a great tire. Don't know if they still make them but the ride was 100% better & quieter. Drove it in pouring rain, no issues. Drove it all winter when there was no snow/salt on the ground. Amazing tire!! You can just transfer your old sensors over with no issue. My 99 sensors were original & still worked fine when I sold the car..
Old Aug 1, 2013 | 12:32 PM
  #35
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
I went with Hankook Ventus V12s and have been very happy. Went non-runflat and the ride improvement is amazing. Just got a cheapo version of the Z06 tire repair kit and taking my chances. As far as the TPMS, my car is a 98 on it's 3rd set of tires and over 100K on the odometer and my TPMS work fine. I wouldn't jack with them if they are still working. Just my opinion. Zuti
Old Aug 1, 2013 | 01:10 PM
  #36
Hernando van's Avatar
Hernando van
4th Gear
Ditto nitto
Old Aug 1, 2013 | 02:56 PM
  #37
hamhead's Avatar
hamhead
As you probably know, your tire pressure when filled with normal air can vary several psi between when it is hot and cold. Nitrogen does not heat/cool as much as regular air does, so your tire pressure remains more stable.
Regular air also has water vapor, which causes temperature swings inside the tire as it heats/cools and can also degrade the rim/inside rubber of the tire.
To New Tire Question's
Old Aug 1, 2013 | 03:32 PM
  #38
PryOpenUr3rdEye
Nitrogen is for Le Mans and F1, you do not need it in a street car. Plus, the theories and benefits of nitrogen have been proven to be minimal at best
Old Aug 1, 2013 | 03:33 PM
  #39
Zuti's Avatar
Zuti
CI 6-8-9 Veteran
What you're saying is essentially true, but the normal air we breath is 80% nitrogen and the amount of water vapor in the tires with standard air is insignificant. The whole $5.00/tire to install nitrogen is just a money making scam in my opinion. But again, just my opinion. Zuti
Old Aug 1, 2013 | 03:39 PM
  #40
hamhead's Avatar
hamhead
I definitely agree, I personally wouldn't pay for it. Just explaining the reasoning behind it.
