1st timer (plastidip)
Old Aug 16, 2013 | 05:28 PM
wolf10851's Avatar
wolf10851
ok here is the big question though..........did you use the glossifier or did you leave it flat black?
I ask only cause I just got done with the first coat of black on mine
Old Aug 16, 2013 | 06:03 PM
oldschoolvette's Avatar
oldschoolvette
looks good
Old Aug 16, 2013 | 10:08 PM
703's Avatar
703
No glossifier was used.
Old Aug 17, 2013 | 05:18 AM
wolf10851's Avatar
wolf10851
ok bigger question now as I said earlier I had just put on my 1st coat. well I had 4 good coats on then I pe3eled the tape off and the plastidip stuck to the tape in places and ruined the whole thing what is a good way to peel the tape so the plastidip stays on the car and does not stick to the tape?
Old Aug 17, 2013 | 09:55 AM
703's Avatar
703
A lot of people recommend taking the tape off while the dip is still wet and this will give you a clean line.
Old Aug 17, 2013 | 07:40 PM
wolf10851's Avatar
wolf10851
but then you would need to retape it for each coat right?
Old Aug 17, 2013 | 08:26 PM
703's Avatar
703
No, Just don't let the coats dry fully. When I did mine I went over it light at first and then just got heavier until everything was covered. Overall it was probably 2-3 coats but in a short amount of time so it was still wet when I pulled the tape off.
Old Aug 20, 2013 | 10:02 PM
wolf10851's Avatar
wolf10851
how durable has it been? since I had to pull mine off I realized how easy it does come off and I am wondering how it would hold up to washing the car, rainy weather, etc...
