What about air in the system? Isn't there a good chance that you will inadvertently introduce air bubbles into the system. What about when it comes time to refill? Maybe I'm missing something?
You missed the part about pulling a little fluid into the tubing from the upper reservoir first before inserting the tubing into the bottom where the actual piston is, then pulling out however much you need to perform the flushing maintenance.
Filling is done by pouring in fluid into the reservoir from your bottle of brake fluid.
Of course you still have to be careful, that's common sense.
Reason: addition
Still don't understand how? You can't really run it through the master.
The fluid reservoir and the actual clutch cylinder assembly are split. The cylinder assembly is about 18 inches below and connected by a tube from the reservoir. To clean out the cylinder area directly, you have to use a tube and method that will slide down inside the connecting tube of the brake system to get to the cylinder assembly allowing you to flush out that part of the system.
There is a bleed underneath the car, if you want to hazard it and make a mess. This is much easier and faster. Seems to get great results, too.
OP thanks for the tips. Ive done this before & used a turkey baster, however I now see I only partially cleaned it as I did not get below the reservoir.
I will try this on the weekend!!
I used a baster as well. Someone else on here used the method I described and I went about finding parts for it for myself. I wanted to publish my list of part numbers so others could find them if they couldn't find the parts from the previous posting introducing this method.
It does require you to use gloves and protect the car from accidental splatters, but works really, really well from what I can tell. I just didn't realize that the flavor injector from Wallyworld was glass and broke my first one. Now I know to be more careful with it.
Need to see a pic of this, still doesn't make sense.
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Actually I thought that most of the forum already had the best method. A remote bleeder. Best $50. I've spent on this car by far. No clutch job should ever be done without adding the remote bleed system.
I'm with these guys....pics would be worth a thousand words....
A nice how to with pics would be awesome
I had already done mine when I started the picture taking exercise. My wife had the camera with her, so I had to wait. I'll have to see if I can roundup my son to help with pics and do a demonstration run one evening.
Reason: forgot something.
Originally Posted by 3boystoys
How does this setup get all the way down into the slave?
not possible... this method will clean the reservoir and that's about it... the line on the bottom of the reservoir to the clutch master is already pretty small, you would need a tiny hose to try to fish it through the bottom of the reservoir and down that line to the top of the clutch master... you could remove the drivers fender liner and remove the line from the top of the clutch master to drain the reservoir but that is just too much work for not a lot of difference in my opinion... the only way to fully replace the fluid in the system is to bleed at the slave or using a remote bleeder... there is no way you can fish a small hose through the reservoir, through the clutch master, and down the clutch line all the way to the slave... good luck with that
This is what I thought, I would still like to see his pics to see what he thinks he's doing.
I'm guessin the idea is to disconnect the tube from the reservoir and fish the tiny tube through there.....
You are completely wrong. The tubing outside diameter is smaller than the inside diameter of the clutch assembly tube. It slides down just fine. Others have done it too, just do a search. This is just my collection of parts to accomplish what others have already done. Hello.....
