My Clutch Flush Solution
At Auto Zone, you'll pick up the following tubing:
At Walmart, you'll get the following:
The Flavor Injector is made of glass. BE CAREFUL WITH IT. I broke my first one, they are ultra-sensitive to bumps on hard surfaces. Apparently the glass has a lot of stresses around the needle assembly.
The needle screws in, so it is easy to modify. You'll need to cut it at the UPPER opening shown in the photo. Use your favorite method, just be sure that when you're done, it has no rough edges that can snag on the tubing and damage it.
Then it is a matter of pushing the tubing onto the modified needle:
One of the things I do is to first is to pull a little fluid out of the reservoir into the tubing, then run the hose to the bottom where the clutch piston is, and draw more out. I then push and pull some of the fluid back and forth to agitate loose any sludge in the bottom before I pull out enough to fill the flavor injector which holds less than the clutch reservoir. About three rounds of this and I had clear fluid.
BTW - Wear protective gloves to do this. And cover the nearby painted areas of the car - there is always a stray drop of brake fluid looking to get on your paint!
Could you be anymore cheap?
At some point in the process, you can also remove enough fluid so that it is possible to take a paper towel and wipe out the contaminants in the reservoir.
I plan to try it this way too.
Thanks.
+ 2
I use this:
http://www.autoaccessoriesgarage.com...FYRP3godjTwArA
