[Z06] how much are ls6's going for?
Old Sep 1, 2013 | 07:29 PM
BuddhaZ06's Avatar
BuddhaZ06
Default how much are ls6's going for?
Thinking about selling my ls6 shortblock. It has 126k miles and had new katech rod bolts, perfect circle rings, clevite bearings, and custom grind fti(ed Curtis) cam installed at 117k miles. Cam is spec'd for stock cube n/a. Cam is very awesome to drive with. Could sell with or without it. Plan on selling 243 heads separately because I want the head stud's. It also has ls7 lifters and ls2 chain. I was hoping to ask around $2000 with cam? Idk if I'm far off or not
Old Sep 1, 2013 | 08:11 PM
racebum's Avatar
racebum
that's not really an LS6 anymore, you've changed a lot of it
also no one is going to want to buy a motor without compression and leakdown numbers
Old Sep 1, 2013 | 08:20 PM
BuddhaZ06's Avatar
BuddhaZ06
Probably just gonna keep it then.
Old Sep 1, 2013 | 08:57 PM
AU N EGL's Avatar
AU N EGL
Post this over in Autocross and Road racing. Might find some takers over there
http://forums.corvetteforum.com/auto...te-engine.html
126k miles ?? No offense, a few hundred
Old Sep 1, 2013 | 09:08 PM
BuddhaZ06's Avatar
BuddhaZ06
Lol it's worth less than a 4.8? Wow I'll keep it.. Runs low 11's all day
Old Sep 1, 2013 | 09:42 PM
Supercharged111's Avatar
Supercharged111
Whole motors are in the 3000 range, except for some local idiot asking over 4000 for one.
Old Sep 1, 2013 | 10:04 PM
racebum's Avatar
racebum
mileage isn't really the problem. you can have a 20k motor with toasted bearings and down compression
someone that's savvy enough to swap engines will want to see the bearings and leakdown numbers
if those are off you have something worth a few hundred bucks
as stated a nice stock complete ls6 with good compression and little to no wear in the bearings will fetch 3000 pretty easily
Old Sep 1, 2013 | 10:15 PM
BuddhaZ06's Avatar
BuddhaZ06
Probably just plan on keeping it unless someone local wants it and knows its history. On the bolt on and stock cube n/a fast list
Old Sep 1, 2013 | 10:34 PM
racebum's Avatar
racebum
if you do a leakdown test with the heads on and take pics of the crank and bearings it shouldn't be hard to sell.
i'm sure you can understand why this is a concern to people
Old Sep 1, 2013 | 10:42 PM
ZeeOSix's Avatar
ZeeOSix
Guess I don't quite understand this. Wouldn't it be worth more with the heads on it? Are heads stock, or have work done to them?
Old Sep 1, 2013 | 11:22 PM
BuddhaZ06's Avatar
BuddhaZ06
Stock with springs. I want to reuse head stud's for myself.
Old Sep 2, 2013 | 12:35 AM
ZeeOSix's Avatar
ZeeOSix
Why not sell it with the heads on and buy new studs? Are these like the only ones of their kind in the world? (j/k)
Old Sep 2, 2013 | 11:17 AM
BuddhaZ06's Avatar
BuddhaZ06
Arp's are just really expensive especially if my engine is only with a few hundred bucks
Old Sep 2, 2013 | 11:18 AM
Supercharged111
if you leave it all together you could sell the engine for a lifetime supply of head studs. . .
Old Sep 2, 2013 | 04:56 PM
BuddhaZ06's Avatar
BuddhaZ06
Lol I'm just gonna keep it and boost it. 243's are easy to sell and I can find someone that wants a custom grind Ls cam . thanks for the replies though
Old Sep 2, 2013 | 06:14 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
I sold my 87k mile LS6 minus the oil pan and accessory drive for 2,500$
To how much are ls6's going for?
