c5 exhaust weld
Old Sep 24, 2013 | 08:46 PM
wlean99's Avatar
wlean99
St Jude Donor '14
Default c5 exhaust weld
posted already not sure where it went.
99corvette manual trans 33,600mi, completely stock exhaust. cracked weld completely off rt rear exhaust where it bolts to flange ,can this be successfully welded back on? Should it be performed on or car or on bench? approx what would one expect to pay,wl from n.j
Old Sep 24, 2013 | 10:11 PM
This has happened on more than one Corvette. Yes, it can be rewelded back on. The price will vary from shop to shop. Just check around and see what they charge.
Old Sep 24, 2013 | 10:56 PM
JDS99's Avatar
JDS99
Happened to my '99 at 50k miles. Upon inspection, it wasn't as much of a crack on mine as it was almost no penetration of the factory weld. The original orientation should be visible where the pieces line up. That's how I marked mine to have it welded back on while off the car. Make sure the welder knows it's cheap 4xx series stainless, not mild steel.
Old Sep 25, 2013 | 05:43 PM
wlean99's Avatar
wlean99
St Jude Donor '14
Default C5 exhaust weld
Thanks for quick reply guys,i had a feeling i wasnt the only one this has happened to.and yes i agree it looks as if the flange was never penetrated when welded,wl99
Old Sep 25, 2013 | 06:59 PM
wlean99's Avatar
wlean99
St Jude Donor '14
Thanks for the info,just learning to use this excellent forum,by the way thats a really nice looking vette!
Old Sep 25, 2013 | 11:52 PM
1999corvettels1's Avatar
1999corvettels1
Happened on my car in 2005, I went somewhere, came back out and started car it sounded weird, looked out back and the 4 tips were out of alignment.
Ended up just buying a used set with factory chrome tips off Craigslist for 100 bucks, mine were not chrome tips.
The flange gaskets I paid a fortune for though at a GM Dealer as I could not seem to find them anywhere.
Old Sep 26, 2013 | 12:01 AM
1999corvettels1
I'm thinking mine was a poor weld also.
I was a hillbilly and drove the car for a long time with no mufflers, at first i thought it sounded good, but it would pop on deceleration like a old clunker, finally I got tired of it, the used mufflers were more quite, but also the tone sounded good and deep, refined vs no mufflers like a loud high pitch sound.
I used a 3 ton harbour freight jack, and more than 1 phone book and pieces of wood to get the car high enough, to get the angle need to get the mufflers in and out.
I was very nervous and never got under the car while doing this, if I would have known, I could have bought a used Z06 set of mufflers, but for a hundred bucks, it's ok.
I'm gonna say you pretty much need a car lift to do this job, you have to get the back way up high to slip those pipes over the suspension, also lower the sawy bar out of the way.
Old Sep 26, 2013 | 12:08 AM
1999corvettels1
Oops, "sawy" about my bad spelling, drinking beers lol!
Old Sep 26, 2013 | 12:19 AM
Bill Vett's Avatar
Bill Vett
The smart way to do this repair is to take the car to a shop that has a lift, you need to get the back jacked up a minimum of 29 inches. Lower the sway bar ......just take it to a shop
Old Sep 26, 2013 | 03:08 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Been there done that. Just another fine example why GM needed a bailout. Bought the ZO6 exhaust as a fix.
To c5 exhaust weld
