Need Advice Help!!!
Old Oct 6, 2013 | 06:01 AM
Atrain59's Avatar
Atrain59
Default Need Advice Help!!!
Ok here is the story. Yesterday (10/05/13 from 5pm to about 3am I was driving my Corvette around town stopping at random places for maybe about 2 hours a piece if that. Right before I left for home I had a couple friends come out and look at the car. I cranked it and let it ideal for about 4-5 mins as we talked. They wanted to hear it reved so I did, reved it to about 5500 rpms and that was it. It came back down to an ideal making no noise what so ever said a couple more words and I left. As i was leaving I noticed my reserve fuel light was on so I pulled in to the local RacTrac gas station to put some gas in it(which was about 2 miles down the road). I had a guy come up to me looking over the car saying how beautiful it looked and how great it sounded. We talked for maybe about 2-4 mins while i pumped gas. I only put 3.5 gallons of 93 gas in the car. Wave bye and drove next door to the taco bell drive through to order some food. As soon as I get ready to order the car starts ticking LOUD and starts jerking, lose of power and shuts off. As it starts to lose power I give it enough gas to coast out of the drive through and find a parking stop. I get out of the car wondering what the hell is going on at this point another guy drives over and ask whats wrong told him "i do not know". He goes on to tell me that the same thing the other guy told me that "he saw and heard the car when I pulled in the gas station and it looked and sounded amazing! and that as soon as I made it over to the drive through he heard it start ticking very loudly" He went on to advise me not to crank it again (which I didn't) and he thinks it dropped a valve or something". After that guy left, my attention turned to the gas station. I started wondering if I got bad gas from the pump? I walk over to the gas station and talk to the manager who was very friendly and helpful. I proceeded to tell her what I thought happened and told her that I am not here to BS you I have a witness that saw and heard the car running before I shut it off to get gas and that I am a Deputy Sheriff and have no reason to make this up. She takes down my name and number and proceeds to tell me that 93 was low as it only had 3600 gallons and usually has 9000 gallons. I then asked for the corporate number. She gave it to me and told me know one will be available til Monday FML! After that I walked outside and got the original guy that saw and heard the car witness statement, just to cover me and back me up and prove that I was not lying about what happened.
So here I am know, trying to figure out what the hell happened. The car had no problems what so ever before this. My only guess would be that I got bad gas and it caused this. I mean I drove the car all day with out a single problem until after I put gas in it. Am i right to think that? What do yall think?
A little information about the car it's a 1999 FRC with 60,000 miles and it has full bolt ons and has a MS3 cam.
Old Oct 6, 2013 | 08:14 AM
PeterB's Avatar
PeterB
Old Oct 6, 2013 | 08:29 AM
sfc rick's Avatar
sfc rick
First thing you should do before you start making accusations, is to pull the valve covers and see if in fact you do have a dropped valve or valve train damage. I'm thinking if was bad gas there would be no damage and just trash in the fuel system.
Old Oct 6, 2013 | 10:16 AM
calvins's Avatar
calvins
Oldtimer
Originally Posted by 8VETTE7
More likely a broken valve spring than bad gas. High revs on an unloaded engine is not a good idea. Especially a modded one.
I'd bet the gas stop was an irrelevant coincidence.
Old Oct 6, 2013 | 10:41 AM
Eric Reeves's Avatar
Eric Reeves
Definitely pull the valve covers FIRST and check all springs. Second check for any codes. I say that from experience. My car did not make any noises it just died. I checked codes first and found both body control modules had lost comm with the ECU. No problem I thought it was a ground issue. So I decided to see if it would at least start again. That is when I cracked the block with a dropped valve. If I would have pulled the covers first I would have found the broken valve spring on #2. Could have been saved if I would have done that. BUT NO, I had to know if it could start because I was going off the codes.
Old Oct 6, 2013 | 11:26 AM
Big Duk's Avatar
Big Duk
Not caused by fuel. your revving most likely broke a valve sprng. I'd bet $$.
Old Oct 6, 2013 | 11:43 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Old Oct 6, 2013 | 12:49 PM
bobeast's Avatar
bobeast
Everything is fine until it isn't. I'm betting the problem has more to do with the revving than the gas.
Old Oct 6, 2013 | 01:01 PM
slocobra's Avatar
slocobra
another vote for valve spring! During the "look how badass my car revs up" event...lol We are all guilty of it.
even if it was bad gas, it wouldnt have been to the fuel rail yet most likely.
Old Oct 6, 2013 | 01:23 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I am going with valve springs also, The C5 has a history of broken springs and revving the motor caused an issue, If you got bad gas it wouldn't make a ticking noise, It would just run bad from the fuel. As others have said pull the valve covers and take a look.
Old Oct 6, 2013 | 01:39 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Many people succumb to bad gas from taco bell.
But your car prolly died from over revving with no load.
Like they said, lucky if it's a spring. Unlucky its a lobe. It could also be a roller rocker, they are bad at losing needle bearings.
Old Oct 6, 2013 | 02:29 PM
Does sound like a valve spring could have let loose. Best of luck getting it fixed and back on the road.
Old Oct 6, 2013 | 09:09 PM
Atrain59's Avatar
Atrain59
Well thanks for all the responses. I had it towed home today and began tearing it down to find that a valve spring broken on #2. I went a head and pulled the spark plugs and going to run more test tomorrow. Hopefully that's all that's wrong.
Old Oct 6, 2013 | 10:15 PM
olbear1962's Avatar
olbear1962
Good luck on the repairs.
Old Oct 7, 2013 | 02:46 PM
Eric Reeves
Exact same as mine. I am surprised it was still running given how your retainer is at the bottom of the spring. That indicates that the valve has dropped ALOT. Here's hoping you do not have major damage although I cannot see how you couldn't at this point. Also check to see if you still have coolant in the radiator. If not its in the oil pan.
Old Oct 7, 2013 | 02:55 PM
jpandes's Avatar
jpandes
Bummer Dude!
I hope you get it fixed with minimal cost and hassle.
Old Oct 7, 2013 | 03:03 PM
Mr.Bill's Avatar
Mr.Bill
Hope you didn't have valve hit a piston, Also hope the block isn't damaged.
To Need Advice Help!!!
Old Oct 7, 2013 | 03:07 PM
Dave68's Avatar
Dave68
Many years ago when I had my 68, I made the mistake of taking someone's mod advice that included installing a cam with very high lift lobes. Unfortunately, the springs were not nearly strong enough and binding occurred twice (at high RPM) before the spring broke (while I was on the way to the garage), the valve dropped and my cylinder, head, and piston were demolished. The cylinder was sleeved, a reconditioned head was installed, along with a new piston, yet the engine was never the same.
Hopefully, yours is not as bad as my 327 was.
Old Oct 7, 2013 | 04:37 PM
slocobra's Avatar
slocobra
pretty certain that head will be comming off. sucks hopefully a quick valve job, new valve, and gaskets and you willbe back on the road.
I just had a broken spring too but they were doubles so inner spring kept from dropping a valve.
I just put these on,
http://www.briantooleyracing.com/660...l-springs.html
beyond exellent customer service,super fast shipping, great quality and never a reported failure! He also has a good deal on spring and retainer packages.
Old Oct 7, 2013 | 04:53 PM
HawnHog's Avatar
HawnHog
Damn bro I about cried when I saw that. How many miles on the engine? I stopped the smokey burnouts and free reving a long time ago. Got a hair over 120,000 miles on my engine. Best of luck on the repair.
