Nitrogen filled tires???
I just use regular air, but it makes me curious.
If the oxygen bleeds out quick enough to matter, then over time the concentration of nitrogen increases since it doesn't bleed out as fast. Each addition to top off the pressure is adding 78% more nitrogen. Over successive air top offs, wouldn't it keep approaching a nitrogen fill?
And cold and altitude seem to have the same damn effect as it does on "oxygen"......so with these cold mornings, my system keeps shooting me "low tire pressure" messages until I roll for awhile.
It's BS as far as I'm concerned and with my experience so far.
S
The reason everyone is treating it lightly is that it has been discussed so much that everyone already has their opinion. You're statement of using "nitrogen instead of air" started it. (air being 78% nitrogen already and adding 100% nitrogen still doesn't evacuate the air that is left in the tire) The laws of physics apply to nitrogen as well as oxygen, so for a passenger car, you're wasting your time and money. Hit 'google' and search nitrogen in c5 tires and see how much literature you come up with.
If you look at basic scientific principles, there are a few simple reasons to use nitrogen in your tires rather than atmospheric air. The most important of which is that nitrogen is produced and sold in a relatively pure form, and other "contaminants" are kept at a low level. The most important contaminant to reduce is water vapour. Water vapor is present in atmospheric air (think relative humidity) and when you would fill a tire the usual way using this air, you pump this water vapour into the tire. Boyle's law states that ideal gases change pressure predictably as the temperature changes (if the volume is kept constant). This is true for nitrogen, oxygen, argon....etc assuming the gases are pure. Now, if you consider water vapour, the same is not true. The pressure of water vapour changes more rapidly with respect to a change in temperture since the operating temperature of a car tire is closer to that of the dew point of the water vapor (the temperature at which a gas changes to a liquid). So basically, fluctuations in temperature will affect a tire inflated with normal air moreso than a tire inflated with a pure ideal gas. Using this principle, any ideal gas could be used instead of air which would allow your tire pressures to remain moreso constant as the tire temperature changes.
Metallurgically, your average wheel is produced using an aluminum alloy. Aluminum exhibits high rates of corrosion and intergranual porosity due to the reactivity of Aluminum. I believe that the face centred cubic structure is more prone to allowing gases to pass through compared to say, the body centred cubic structure of low carbon steel. Nitrogen is a large, inert atom so it does not react with the aluminum in the wheel to form aluminum oxide. Therefore the oxidization of the aluminum is reduced. Water vapour and oxygen atoms in atmospheric air will corrode the aluminum creating a crusty white aluminum oxide film and will eventually enlarge pores in the aluminum over time and cause pitting. Small atoms of hydrogen and oxygen travel through these pores easier than larger Nitrogen atoms.
Lastly, there is no such thing as filling a tire with pure nitrogen. It's not possible unless you draw a -14.7psi vacuum on the tire first, and then back fill it with nitrogen. I personally don't use Nitrogen as pitting and pressure fluctuations are not a big deal to me. Regularly check your pressure and modify as required for daily driving and you'll be fine. For racing though I would recommend using nitrogen in your tires as the temperature fluctuations are more extreme so you can then maintain your set pressures more consistently.
. Thanks for your input Jack
I have a device that plugs into the wall (you can get them that plug into your cigarette lighter) that extract nitrogen from the air and can be added to your tires. It's not 100% efficient, it only extracts about 78% nitrogen and still has about 21% oxygen in it, but it's cheap and easy. I got it at Harbor Freight. It was called "air compressor", I think.
But seriously, my mechanic has a device he claims purges my tires of non-N prior to reinflating with Nitrogen.
Does this device actually do that, or is he just blowing smoke?
