Nitrogen filled tires???
Old Oct 9, 2013 | 10:58 AM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Default Nitrogen filled tires???
Hi guys, just curious if anyone uses nitrogen in their tires rather than air? I'm not sure if it affects the TPMS, but I don't have mine anymore regardless.
Old Oct 9, 2013 | 11:03 AM
kybilt's Avatar
kybilt
From: The heartbreaking shame of pink stars Kentucky
I've been experimenting with a mixture of 78% nitrogen, 21% oxygen in my tires... so far it has worked out great!
Old Oct 9, 2013 | 11:05 AM
STALION's Avatar
STALION
Nitrogen is suppose to stay stable without fluctuation. Do you notice any difference in ride at all?
Old Oct 9, 2013 | 11:06 AM
Brackneyc's Avatar
Brackneyc
I run about 75/25. I feel better now.
Old Oct 9, 2013 | 11:07 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I prefer helium, makes the car lighter thereby faster. Nitrogen is just a gimmick for street cars and daily drivers.
Old Oct 9, 2013 | 11:15 AM
JetMechZ16's Avatar
JetMechZ16
I fill my tires to 122% of their intended final pressure, then let out 22% of it. That leaves me with 100% Nitrogen. The 22% I let out is the 21% oxygen and 1% miscellaneous gasses.
Old Oct 9, 2013 | 11:16 AM
kybilt's Avatar
kybilt
Hydrogen is even lighter than helium, amirite? I may switch to hydrogen!
Old Oct 9, 2013 | 11:43 AM
CQRT's Avatar
CQRT
Old Oct 9, 2013 | 01:29 PM
Camjamsdad's Avatar
Camjamsdad
St. Jude Donor '13
That's a brilliant idea, although it didn't work out so well for the hindenburg. How bout nitrous oxide? You could either go faster or giggle the whole trip
Old Oct 9, 2013 | 01:51 PM
MawneeC5's Avatar
MawneeC5
Old Oct 9, 2013 | 02:03 PM
oldschoolvette's Avatar
oldschoolvette
no
Old Oct 9, 2013 | 02:17 PM
GySgt1811's Avatar
GySgt1811
Search for past threads on this. Nitrogen filled tires are an ingenious solution to a non-existent problem. If a tire goes low, and they do, you have to find a place that fills with Nitrogen to replace it. And if it's not the place where you originally purchased this wonder product you will pay about $25.00 for the service.
In any case the tires will always still have some Oxygen in them because you can't vacuum purge the tires before fill up.
I ran Nitrogen for a few years in my DD. There is absolutely no difference between a 90+% fill of Nitrogen than the traditional, ubiquitous and free 76% Nitrogen, 22% Oxygen, 2% Misc. fill up.
Nitrogen fill up is a gimmick to sell more $hit.
Although, you do get cool little green valve caps to lecture people about when they say, "wazzit?"
Best Regards,
Gunny John
Old Oct 9, 2013 | 02:25 PM
GySgt1811's Avatar
GySgt1811
No. Boyles law. Pressure varies with temperature, same as any other gas. Base upon my several years forced* experience with Nitrogen, it still fluctuates. The temp/pressure curve may be different for individual gasses, but...
Guns
*Durn techs put in Nitrogen without asking when I bought a new set of tires. I stupidly spent another $50-75 bucks over the next two years until I learned (I ain't the brightest bulb in the chandelier!) to just refill with the free stuff. GJ.
Old Oct 9, 2013 | 02:30 PM
s'noJob's Avatar
s'noJob
Nitrogen atoms are bigger than oxygen atoms, so they're less likely to pass through microscopic holes in the tires.
You don't need to worry about topping off the tires with regular air at the pump. What little oxygen that's entering the tire is not going to offset the nitrogen by much.
Old Oct 9, 2013 | 02:34 PM
pmurray's Avatar
pmurray
I put H2O in mine and it rides like my old Cadiliac
Old Oct 9, 2013 | 03:05 PM
Bimmervet's Avatar
Bimmervet
St. Jude Donor '12-'13-'14-'15-'16
I work for Pella Windows and Doors, so I am going to fill my tires with Argon Gas. The car will ride better and insulate me from bumps.
Old Oct 9, 2013 | 03:23 PM
obnoxus's Avatar
obnoxus
To Nitrogen filled tires???
Old Oct 9, 2013 | 06:10 PM
STALION's Avatar
STALION
Holy ***** guys, didn't know everyone was working part time as comic reliefs! In any event thanks....I think!?
Old Oct 9, 2013 | 06:45 PM
Phanni's Avatar
Phanni
Finally, someone with the correct answer.
I get nitro filling for free. However, they nitrogen filled tires in fact, keep your tires at a more stable pressure over time because the molecules are larger and harder to 'bleed out'. Adding a bit of 'free air' would not be a problem due to the ratio involved, however they will need adjustment less often.
For those that don't believe this, do a bit of reading on what causes the 'bends' for scuba divers.
Old Oct 9, 2013 | 07:02 PM
sfc rick's Avatar
sfc rick
I'm ok, never gonna snorkel my vette......oh that's another thread.
