Help - iPhone music and head unit ERROR
Old Oct 16, 2013 | 12:44 AM
david1st's Avatar
david1st
Default Help - iPhone music and head unit ERROR
Need help!!! I have the single cd stock head unit and PHXGM4 for over a year now with no issues and out of the blue when I connect my iPhone up to play music it will connect and play the music for maybe 25 seconds before it drops the iPhone and converts to play radio!!?? CD player and radio works and my iPhone will play the music constantly UNTIL I hook it back up to my PHXGM4 HU after 12 seconds of music play HU displays ERROR and cuts off?? Even though it stops play it still charges the iPhone Any ideas guys?? Thanks for any help.
Old Oct 16, 2013 | 12:56 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
The first thing I would do is check all the connections on the iphone adaptor.
Old Oct 16, 2013 | 10:53 AM
david1st's Avatar
david1st
Don't understand why it would play and after then stop playing?.
Old Oct 16, 2013 | 11:02 AM
Corvette_Ed's Avatar
Corvette_Ed
Sounds like the wire got a break in it. Try another cable and see if it works.
My iPod wire died after just a little more than a year.
Old Oct 16, 2013 | 03:23 PM
Red rag's Avatar
Red rag
Please let us know what you found. I just installed one of these.
Start easy first, check the connection points outside ie. Iphone jack and plug. I agree with Mr. Bill and checking the hidden connections (reseat them). I would also double check those little micro switches. Possibly switching them a few times in the event they have a little corrosion internally. Good luck, gotta rock!
Old Oct 19, 2013 | 05:07 PM
david1st's Avatar
david1st
Thanks for feed back! I hope to have time Sunday to look i
At the switch pins
Old Oct 20, 2013 | 10:22 AM
tsbbzm's Avatar
tsbbzm
Mine has done the same thing, for me it seems to be linked to dead or disconnected battery. If I disconnect the battery from the car, or the battery goes dead, and then hook battery back up or charge battery, then the iPhone/Pod aux quits working. Over time it starts working again. I have taken the unit out and inspected all the wires and hook ups, found no problems. It will work fine until I accidentally leave a light on and run battery dead, or unhook the battery due to working on something, after battery in back on or charged, it stops working again. ERROR is what shows up on the display.
Old Oct 20, 2013 | 11:36 AM
Bill Vett's Avatar
Bill Vett
60 IPC
U1128 Loss of Communications with Radio
I don't know if you have this code or any radio codes but check them and clear them. I'm not sure if this will help but I'd give it a try.
Old Oct 27, 2013 | 04:51 PM
david1st's Avatar
david1st
Well found no codes no set up or wire issue..... But I disconnected and reconnect the car battery and it working fine now!
Old Oct 27, 2013 | 08:28 PM
If it happens again, maybe give Dennis at Double D Mods a call and just pick his brain on this. He knows a lot about the C5 stereo systems and maybe can point you in the right direction.
To Help - iPhone music and head unit ERROR
