Clb
Old Nov 12, 2013 | 06:33 PM
C5Txfan's Avatar
C5Txfan
Default Clb
I had the aftermarket CLB on my previous '01 and now have an '04 that I feel I should put it on also BEFORE I get stuck somewhere. I don't remember where I got my other back '01. It was very easy to install with the plug in to bypass the lock.
Where does everyone that has installed a CLB suggest I look again as I have completely forgot where I ordered it.
Thanks ..
Old Nov 12, 2013 | 09:06 PM
dood73's Avatar
dood73
Compliance Parts has an easy to install CLB called the LMC5. Easy to install and had good instructions.
Old Nov 12, 2013 | 10:09 PM
Most major parts suppliers (like Mid-America, Ecklers, WCC, etc.) should carry the CLB. I bought mine from Thunder Racing, but I believe they are no longer in business.
Old Nov 13, 2013 | 01:51 AM
Zr-1Mike00's Avatar
Zr-1Mike00
Corvette's of Houston sells one, super easy install.
http://corvetteworldparts.com/43-cor...mn-lock-bypass
Old Nov 13, 2013 | 08:14 AM
wbrands's Avatar
wbrands
And Richard there is a big help if you have a problem with the install.
Old Nov 13, 2013 | 08:19 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
get the CLB ....from one of the places listed above...I continue to see issues with the other one....you shouldn't need tech support for what should essentially be a plug and play device
Old Nov 13, 2013 | 09:36 AM
bj1k's Avatar
bj1k
Good product , great customer support.
Old Nov 13, 2013 | 12:39 PM
C5Txfan's Avatar
C5Txfan
Thanks everyone .. just ordered one from Compliance Parts as it seems easier to install than the last one I got before. Don't have to take all the plastic trim off, etc. - plus a little cheaper.
Old Nov 13, 2013 | 08:55 PM
pewter99's Avatar
pewter99
easier than 2 screws.. 10 minutes, one plug? ok
Old Nov 14, 2013 | 12:18 PM
C5Txfan's Avatar
C5Txfan
Well the one I put on my '01 was a 'little' more than that. Took about 30 - 45 minutes. Guess I'll find out ...
Old Nov 14, 2013 | 04:49 PM
TEXHAWK0's Avatar
TEXHAWK0
Being the curious type, even though the LMC5 removes the actuator from the system, I would still want to look under the dash to see what other fixes may have been installed, and remove anything that does not need to be connected...
Old Nov 14, 2013 | 06:10 PM
C5Txfan's Avatar
C5Txfan
I really think there's not any other fixes as wheel still locks and unlocks (so far). I hear the 'zip' when I take key out and 'zip' when I start it. If there is another 'fix' it ain't workin' !
To Clb
