Burned CD
Old Nov 16, 2013 | 09:33 AM
hb4lthr's Avatar
hb4lthr
Default Burned CD
I have a very unusual question. About a week ago, I burned a CD. The CD plays fine in my home Bose unit and in my 2008 Infiniti G37. I also have a 2004 Z06 vette. To my surprise when I tried to play the CD in the Z06 it doesn't play. Has anyone ever experienced this or know what could be causing the issue?
Old Nov 16, 2013 | 09:49 AM
GCG's Avatar
GCG
In which format did you burn the CD tracks? Are they MP3? If they are, thats' the reason it doesn't play.
Old Nov 16, 2013 | 09:53 AM
JaxEagle's Avatar
JaxEagle
You could rip them all to your iPod and then it won't be an issue.
Old Nov 16, 2013 | 10:45 AM
JR-01's Avatar
JR-01
You're assuming everyone has an iPod.
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
My burned CD's were having issues in my car.
I cleaned the laser and they are good now.
Procedure on my web site on how to clean the laser.
www.ToqueZ06.com
And ... no, that laser cleaner disk you just stick in does NOT work.
Toque
Old Nov 16, 2013 | 10:46 AM
JR-01's Avatar
JR-01
My guess, too. CDs burned in MP3 won't work in my 2003 GMC.
Old Nov 16, 2013 | 10:54 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I am not sure on the C5 CD players, but on some others, the format of the disc can make a difference.
Some recordings have an option to finalize the disc. If not finalized (to allow additional recording) it may not play in some players.
Some players will not work with rewritable CDs. Most normal one time write CD's work in most players.
Some players do not like CD text (like the song name, artist, etc).
As stated above, MP3 format will not work.
I don't know if any of these are your issue, but they are some that I have run across.
Good luck.
Old Nov 16, 2013 | 12:33 PM
VinnyT's Avatar
VinnyT
Has to be a CD-R not a CD-RW. The CD-RW are thicker which causes issues in older CD players. Ask me how I know.....
Old Nov 16, 2013 | 01:29 PM
hb4lthr's Avatar
hb4lthr
Thanks everyone. Actually my wife burned it so I asked her and she did say it was MP3. I guess I am wondering why it plays every where except in the vett??
Old Nov 16, 2013 | 01:30 PM
hb4lthr's Avatar
hb4lthr
Vinny. It is a CD-R. So why it still having issues?
Old Nov 16, 2013 | 01:32 PM
JR-01's Avatar
JR-01
Older CD players do not play MP3 format. They don't play in my 2003 GMC truck either.
Old Nov 16, 2013 | 02:35 PM
Pintoblades's Avatar
Pintoblades
What format should they be burned assuming it's a CD-R and Mp3 type doesn't work?
Old Nov 16, 2013 | 02:54 PM
JR-01's Avatar
JR-01
Audio file?
Old Nov 17, 2013 | 11:24 AM
MacNH's Avatar
MacNH
St. Jude Donor '14-'15-'16-'17-'18-‘19
I believe in the Beer Fairy
Originally Posted by JR-01
Audio file?
CDA (CD Audio) works fine.
Old Nov 17, 2013 | 11:38 AM
FNFastZ06's Avatar
FNFastZ06
MP3 formatted CDs weren't commonly used in 2003-4 so not supported in those era stock players in autos.
Another issue that caused problems replaying in autos was the laser type used. Some couldn't read certain disks with colored coatings. I had to try several different brands in my old '97 until I found one that worked. IIRC the green and blue colored discs didn't but the gold ones worked fine.
Old Nov 17, 2013 | 12:15 PM
CactusCat's Avatar
CactusCat
Ok hb4lthr, give this a shot. Had the same issue here. Cleaning didn't fix. All my CDs are CD-Rs. The problem is related to the brand of CD you're using. I was using some Phillips silver CD-Rs and while they play on everything else I own, they would NOT play in the Vette's Bose HU. I could experiment with a few things and on rare occasion get one to work for a little while. It has to do with the chemicals and reflectivity of the brand CD-Rs you're using. Just try a different brand/type and you'll find they work fine. In my case, I used some cheap-john HP CD-Rs I got a couple of years ago for $5 for spindle of 50 at a Black Friday sale. Guess what? Everyone of them works PERFECTLY in the Bose Hu.
To address another question, there is a free CD/DVD burning program called Deep Burner that will convert your MP3s into correct audio format. Just run it, select Create Audio disc, copy your tracks to the program that you wanted included on the CD and then click burn. Easy peasy. If you need a link to it, here you go:
http://www.deepburner.com/?r=download
Any questions, just holler. I do IT support work for a living for almost 30 years now.
To Burned CD
