Car gets sideways
Old Jan 10, 2014 | 02:50 PM
Lt. Dan M.'s Avatar
Lt. Dan M.
Originally Posted by Corvette_Ed
Comp mode is a lot of fun and the car handles differently, but the driver needs sufficient skill to use it safely. TC isn't on in this mode, only AH, so if the car starts to slide it's all on the driver to control it.
Isn't TC just for wheel spin and AH for keeping the car straight? I thought that was the idea of comp mode, that you could spinn but still have the added safety of AH to help keep you from getting to sideways.
Old Jan 10, 2014 | 03:01 PM
pmurray's Avatar
pmurray
I like letting her rip as I come on to an on-ramp (With no one around). I get a bit sideways because of the slight turn, then drift a bit, straight it out and then shift. Here's where you must not over steer or you end up in the ditch.
Old Jan 10, 2014 | 03:34 PM
85corvettec4's Avatar
85corvettec4
Just the car man, enjoy it!
Old Jan 10, 2014 | 04:07 PM
Bluefire's Avatar
Bluefire
I experienced the same thing. The back tires wanting to pass the front tires on the right side. I may be crazy but, I swear that it stopped happening when I switched to coil-overs. Could the transverse leaf springs been contributing to the rear-end stepping out?
Old Jan 10, 2014 | 04:27 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I've paid alot of good money for my car to act like that.
But seriously take a look at your rear tire choice first off. Then research it for traction/stickiness. You give up tire life but a good sticky tire will change the way the car hooks up. A hard tire, like original runflats, slip and slide and don't hook up well
Old Jan 10, 2014 | 04:32 PM
robert miller's Avatar
robert miller
Originally Posted by Toque
To the OP here your's is a special corvette has to be my car still don't do that. Cant I get some help from a few of you guys to see what is wrong with my car...I can tell you this dam thing like gas.. Robert
Old Jan 10, 2014 | 04:53 PM
MG RED 99's Avatar
MG RED 99
Please correct me if im wrong, but in competition mode, traction control is turned off which will allow you to spin the tires but active handling remains on to keep from getting sideways. Comp mode is what I use at the dragstrip. If you keep it straight then AH never jumps in, but it's nice added insurance if the car breaks loose, like in a missed shift at the top end of the track going from 4th to 5th but putting it in third by mistake. Scary but the car stayed straight and seemed to perform the way it was intended, by intervening to keep the car straight at over a hundred mph. It could have been worse had the trac/AH been turned off completely. Unless you're trying to drift the car I see no reason to ever turn off AH.
Old Jan 10, 2014 | 04:58 PM
Corvette_Ed's Avatar
Corvette_Ed
You guys are misunderstanding what I was saying. When you have wheel spin in Comp mode it can get sideways, and AH is supposed to kick in at that point, but AH can only compensate for physics so much. At some point the physics is stronger than AH can manage.
Old Jan 10, 2014 | 05:26 PM
95wht6spd's Avatar
95wht6spd
cold weather does not help.
Old Jan 10, 2014 | 07:26 PM
jdot's Avatar
jdot
Good grief, so many buttons and advice on how to put yourself in a ditch with style. If you've got to have "buttons" to help you stay under control you really missed driving cars back in the 60's like some of us old farts when it was just you, the accelerator, the brake and your skill.
Old Jan 10, 2014 | 07:42 PM
Mattie Num Nums's Avatar
Mattie Num Nums
Quite honestly even with my power I have only had the car kick 2 times and both where after 20+ laps in 90+ degree weather. TC off as well.
Old Jan 10, 2014 | 10:30 PM
Lt. Dan M.'s Avatar
Lt. Dan M.
Watch the video clip in thread "please don't let this happen to you" Yeah, they get sideways....
Old Jan 11, 2014 | 12:11 AM
  #33
cbhood's Avatar
cbhood
Originally Posted by calivette805
Buy better tires
Actually these were the kinds the answers I was looking for. I understand traction control, active handling, competition mode. I'm by far not as good a driver as many of you but understand power and counter steering and it just seems like when you aim a world class sports car in a straight line it should stay in a straight line. I know stiffer sway bars will help reduce twisting in the curves making it more stable. Will it have any effect on the kicking out? Do 911 Porsches do this?
Old Jan 12, 2014 | 12:46 AM
  #34
C5at16's Avatar
C5at16
Originally Posted by FRANK J CARCIA
Don't turn TC off you will get more then sideways.
I'm running stock tires, when TC is off I just spin and go straight. No sideways here! :p
Old Jan 12, 2014 | 10:10 AM
  #35
Hauln1203's Avatar
Hauln1203
Amen brother my thoughts exactly!!!!!!!
Old Jan 12, 2014 | 11:41 AM
  #36
Corvette_Ed
Then you're not doing it right.
Old Jan 12, 2014 | 12:58 PM
  #37
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I've found that turning the traction control off, gripping the steering wheel firmly with both hands, mashing the accelerator to the floor, and closing my eyes works well.
To Car gets sideways
Old Jan 12, 2014 | 01:09 PM
  #38
C5at16's Avatar
C5at16
The swirly corners are when I am feeling devilish I just supercharged my car, it's stupid now. I spin going 70 with TC on :o
Old Jan 12, 2014 | 01:18 PM
  #39
Corvette_Ed
Spinning can be fun.
Old Jan 12, 2014 | 01:49 PM
  #40
reactor2's Avatar
reactor2
The fact that you can break the tires loose in an A4 is amazing. Not stock? 3.15 rear? My stock A4 with 2.73s couldn't break the tired loose just by punching it. Now my modified vette will go sideways at 70 mph.
