Car gets sideways
Old Jan 10, 2014 | 12:36 AM
cbhood's Avatar
cbhood
Default Car gets sideways
I have an automatic. If you punch it from a dead stop does your car kick sideways and the active handling come on when you hit second gear? or am I just special. My son calls it "the ax murderer" Is there a handling fix recommended to help keep the car in straight line? (Ya I know...learn to drive)
Old Jan 10, 2014 | 12:49 AM
Kreeess's Avatar
Kreeess
Some of the guys here have their cars kick sideways all the way to 4th... Corvettes are torque monsters, only fix I can come up with to keep the car straight is "driver mod" ... More seat time! Enjoy gettin sideways
Old Jan 10, 2014 | 12:54 AM
zagger's Avatar
zagger
AH will come on every time your tires brake free and spin, that is what it is suppose to do. You can disable AH and TC via the little button by the shifter. As for the car going sideways there can be many things causing it. Bad alignment, high crown in road surface to name few.
Old Jan 10, 2014 | 01:11 AM
cbhood's Avatar
cbhood
Mine does too, but 2nd is a bit unnerving. I'll work on my skills.
Old Jan 10, 2014 | 01:21 AM
damilleniumboy's Avatar
damilleniumboy
noob question right?
Old Jan 10, 2014 | 01:42 AM
cbhood's Avatar
cbhood
Obviously. I've had the car for a year or so, but having never owned one before, just not sure what I should expect from the car and what is normal. I've spent allot of time on the forum and never seen anyone mention this before. I take it this was a stupid question.
Old Jan 10, 2014 | 02:09 AM
calivette805's Avatar
calivette805
Buy better tires
Old Jan 10, 2014 | 03:53 AM
LS1 Goat 91's Avatar
LS1 Goat 91
You need to roll into it. Of course it's going to spin if you just mash it from a dead stop on street tires. But it's also more fun
Old Jan 10, 2014 | 07:54 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Sideways? I've never heard of such a thing.
Old Jan 10, 2014 | 08:16 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Old Jan 10, 2014 | 08:59 AM
Fcar 98's Avatar
Fcar 98
Don't turn TC off you will get more then sideways.
Old Jan 10, 2014 | 10:38 AM
DevilDog II
Oldtimer
Originally Posted by Toque
Old Jan 10, 2014 | 10:41 AM
Traction control is designed to limit wheel spin. AH helps control the car when sideways movement is detected.
From the Owner' Manual:
ACTIVE HANDLING SYSTEM
The Active handling system is a computer controlled system that helps the driver maintain directional control of the vehicle in difficult driving conditions. This is accomplished by selectively applying any one of the vehicles brakes.
TRACTION CONTROL SYSTEM (TCS)
Your vehicle has a traction control system called TCS that limits wheel spin. This is especially useful in slippery road conditions. The system operates only if it senses that the rear wheels are spinning too much or are beginning to lose traction. When this happens, the system works the rear brakes and reduces engine power (by closing the throttle and managing engine spark) to limit wheel spin.
To the OP - your car is doing just what it is designed to do with AH active. It senses the sideways movement and engages the AH system to straighten the car back out. Mine does the same thing.
Old Jan 10, 2014 | 10:56 AM
Fcar 98's Avatar
Fcar 98
Sorry i stand corrected. My does not have AH so if I turn TC of it will do loops if I won't. thanks.
Old Jan 10, 2014 | 12:24 PM
Kreeess's Avatar
Kreeess
our 98s are just built to have MORE fun!
Old Jan 10, 2014 | 12:42 PM
Corvette_Ed's Avatar
Corvette_Ed
If my car wasn't getting sideways when I punched it while at a dead stop I'd be wondering what was wrong with it.
OP just needs to find a large, empty parking lot and get in some launch practice. Getting sideways is part of the fun of owning a muscle car. Then comes the fun of Competition Mode.
Old Jan 10, 2014 | 01:27 PM
66dts-v's Avatar
66dts-v
I still haven't put Comp Mode to the test, yet. Hell, I haven't done a donut yet.
I've had it 6 weeks, still getting used to the added power and handling compared to my old C4.
To Car gets sideways
Old Jan 10, 2014 | 01:38 PM
Corvette_Ed
Comp mode is a lot of fun and the car handles differently, but the driver needs sufficient skill to use it safely. TC isn't on in this mode, only AH, so if the car starts to slide it's all on the driver to control it.
Old Jan 10, 2014 | 01:40 PM
Kreeess's Avatar
Kreeess
since my car is a 98 I havent experience AH yet,
only TC OFF
Old Jan 10, 2014 | 01:46 PM
66dts-v's Avatar
66dts-v
I have skillz, but I drive within the limits of my ride and I haven't pushed Ester hard yet. But I really like the idea of what it does.
My little brothers C6 has a few different settings I've played with a little. But there is a lot of gravel on the roads right now and I haven't played in the parking lot at work yet. But I will.
