Yaw Sensor maybe?
Old Jan 28, 2014 | 12:49 PM
chipscvettec5's Avatar
chipscvettec5
Default Yaw Sensor maybe?
DIC indicates Service Engine Soon, Service Active Handling System, Service Traction Control. 2001 with 34K miles. So, won't know for sure until we check around and possibly pull the ABS module. For the forum, I'll let you know what I find out.
Old Jan 28, 2014 | 01:07 PM
Jim Taylor's Avatar
Jim Taylor
I don't know. I've gotten those messages with my 2000 sometimes when I haven't driven it in a while. They go away when I restart the car. Maybe it's nothing, or maybe just a low battery?
Old Jan 28, 2014 | 01:18 PM
PRE-Z06's Avatar
PRE-Z06
Have you checked the codes through the DIC to see if it's maybe a wheel speed sensor?
Old Jan 28, 2014 | 03:03 PM
dadaroo's Avatar
dadaroo
Codes, codes, codes? Why would you start pulling parts first? What would you do after you pull the EBCM anyway?
You better first make sure the battery is charged with at least 12.5 to 12.7 volts at the battery.
Pull your codes and record them. Clear them and with a good charged battery let us know what happens after a drive.
Don't mean to sound harsh but let's do this logically.
Old Jan 28, 2014 | 08:26 PM
jrose7004's Avatar
jrose7004
When mine did that it was the steering sensor.
Old Jan 29, 2014 | 03:33 AM
DeeGee's Avatar
DeeGee
I've already had a new EBCM after a C1214 code. My C1287/C1288 is a SWPS issue
Thats why you need to check the codes.
Unlikely to be a battery issue without a bunch of other indications such as dropped memory settings.
To Yaw Sensor maybe?
