hi, I have an 01 zo6 with a c6 shifter installed. for a while, it began harder to get the car in first gear than usual. the only way to ensure the car would go into first was to put it in neutral, bring the shifter all the way to the right, and then bring it back to the left and put it first. otherwise there was a good chance I would end up in third.
lately, though, it now makes a grinding noise/rattling every time I put it in first unless I put it in neutral and bring it all the way to the right before going in first (putting it in reverse first also prevents the grinding).
what do you guys think the problem is and how much to fix it? I heard it may be the synchronizer. thanks in advance.
i would take apart your center console ..which is very easy to do....and check to see if your shifter is aligned properaly
I agree, that is the FIRST thing to do. If you have to drive the car do whatever you have to do to prevent the grinding, including starting in second gear.
Might be coincidence with the shifter and your 1st gear syncros are going out. My 1st did and all I had to do was never put it in first while moving unless I put it into 2nd first and then slid into first. You would never know anything was wrong. If that works for you...nothing to do with shifter.
I respectfully disagree. You need to make sure your shifter is properly aligned and the mounting is not loose. If it is out then even the above could then lead to 2nd gear problems.
Use this link to verify/correct shifter alignment. Make sure the bolts are properly torqued and that the bushings are not worn out where the shifter box mounts to the torque tube.
Also, there is a small ground in the rear driver side fender well with a 10mm nut on it. This is the ground for trans sensors and reverse lockout. It wouldn't be a bad idea to clean up this connection for good measure.
Bet I'm one of the few on here that know Cherryville is pronouced Churrville. (I'm from Lincoln Co. too)
Good luck!
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
As mentioned above, check the alignment (very easy),and if you're still having issues, ( I had a similar problem a couple of years ago), I replaced my transmission flud with AmsOil Torque Drive Synthetic. I could not believe the instant improvement in the smoothness of the shifts and all of the grinding and difficult shifts went away. Zuti
... I replaced my transmission flud with AmsOil Torque Drive Synthetic. I could not believe the instant improvement in the smoothness of the shifts and all of the grinding and difficult shifts went away. Zuti
(same tranny fluid I use in my 02 Z06 at the track)
More than happy to get AMSOIL products for forum members at dealer wholesale pricing, about 25% below retail, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
Well, I was finally able to get around to look at my car. Checked the fluid first, and then I tried messing with the alignment. I put in my old B&M shifter in but it didn't fix the problem. Took it out, put my c6 shifter back in (which i have been currently using) and yet again I'm still grinding like crazy in first (unless I go from reverse to first, then it works fine).
Any other stuff I should try before dropping it off somewhere?
It could be the clutch. In racing my 02 Z06 for about 10 years now, I've found the throw out bearing in the clutch is a very weak link. Seals in it seam to go fairly quickly after which you don't get full clutch disengagement. Might not notice is as much in the higher gears as you may naturally be getting revs pretty close such that it doesn't matter. The other piece I've had to replace is the clutch master cylinder. If it doesn't move enough fluid you could get similar symptoms. Of course, it could be the first gear synchro as well, but my guess is clutch.
The clutch could certainly be your problem. Not at home with the FSM. However all my other cars allow you to actually measure the clutch air gap when engaged to verify it is enough/correct. I am certain the C5 must have away to do it. You should just need to get the car in the air. Can be done without running the engine.
I ended up dropping it off at a dealership because we knew a guy that worked there and said he would take care of it. Got a call back today and they said I need a new transmission, and that they found a non-gm one for $4,600. I realize no one on here can actually look at my car, but from the description I provided of the problem, does it really sound like I need a whole new transmission? The car has 95K miles. I was thinking it was the synchronizer or clutch... I couldn't afford the new transmission right now even if I wanted to. Any thoughts? Thank you.
My 1st gear syncro has been bad for a long time. As long as I shift into 2nd then first only at complete stop it doesn't grind and you wouldn't even know there was an issue.
Of course I want it fixed so I am going to do the rebuild with the better forks, etc and I am still looking at $1400 and better than the stock when done.
Mine had a similar problem when I bought it and aligning it didn't fix the problem although it was slightly out of alignment. A combination of a B&M shifter intended for an 08+, 2x spacers for the detent, changing the fluid for the newer GM dex iii replacement and another final alignment seems to have almost completely cured my problems. Does reverse give you any grief?
thanks for the replies. but no, it only grinds when I put it into first. it actually doesn't grind at all when I go from reverse to first. all gears other than first are smooth.
just picked up the car. I told him I was thinking it was the first gear synchronizer and he said it probably was, but that I couldn't just change that synchronizer out, and that I would have to change the main shaft out as well. is there truth to this? can I just not change the first gear sync (if that's the problem) instead of buying a whole new transmission?
I'm having the trans in my 03 z rebuilt right now, tick stage 1 rebuild, monster stage 2 clutch/flywheel, new slave, remote bleeder, and labor for under 3k. Stay away from dealerships. My work is being done by a reputable shop. My rebuild is due to the trans popping out of reverse. If you skipped the clutch, you could have it all done for around 2k.
they told me that gm didn't make the transmissions anymore and that a rebuilt non gm one they found would be 4600 installed, plus 900 for a clutch if I wanted to do that as well.
I don't have 4-6k to spend right now on this. was hoping I could just change the first gear synchronizer.
I have no personal knowledge of the M6 (other than having one) but have done plenty of manual/auto transmissions in the past and I agree it's probably the scyncro. It shouldn't cost 4-5k to fix it though, if you do your own work, even if you did the clutch. (1K) An overhaul vs a replacement with a guarantee.
This post by gtrslngrchris intrigues me
"Mine had a similar problem when I bought it and aligning it didn't fix the problem although it was slightly out of alignment. A combination of a B&M shifter intended for an 08+, 2x spacers for the detent, changing the fluid for the newer GM dex iii replacement and another final alignment seems to have almost completely cured my problems. Does reverse give you any grief?"
I think I read somewhere that the early M6 had paper/composite blockers with the scnycro's. I have had problems with scyncro's becoming bonded/gunked with varnishs and fail to spin freely, thus not doing their job properly. Mostly due to the wrong fluid being used or lack of maintance.... just a thought.
