Headlights ....
Old Feb 25, 2014 | 06:16 PM
andrec10's Avatar
andrec10
Originally Posted by WA 2 FST
I don't drive a lot at night, so I really have never been bothered by the lousy headlights.
But please help me with the nomenclature... I see ACA, JW, Radioflyer... modified ACA housings, Bi-xenon... etc.
I see some people are finding them for $300, and Radioflyer's kit is $650.
What is what? I don't want to cut corners. I'm a good shadetree mechanic, but I don't want to go cutting everything up to get something to work and find it doesn't fit right. I also want to do this ONCE and be done. I don't want too much electrical load/draw on my 12yr old factory wiring harnesses... to me that = fire hazard.
Thx for the help.
The RadioFlyer Bi-xenon have one HID bulb and a shutter moves over for the high beam. The Housings are All ACA replica's. JWM has the housings with HID Low beams and a standard high beam bulb.
Hope that helps. The 35watt ones I believe draw the same as the stock headlights.
Old Feb 25, 2014 | 06:28 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Originally Posted by James2002z06
Thanks Flash .... I should have bought from JW last at the NCCO
I should be there again this year. If you can wait that long we'll set you up. Just let me know.
Thanks for everyone that suggested us. Our units are plug n play and include a 12 page installation guide. Full color. Easy
Old Feb 25, 2014 | 06:32 PM
JW Motorsports
Banned Scam/Spammer
Originally Posted by andrec10
Ordering mine from JWM by the end of the week. I too suffer from embarrassment when turning on my headlights!
thanks for considering us. Contact me direct with any questions.
Originally Posted by LoneStarLizzard
If I'm not mistaken, JW's ACA HID kit comes with the Hi-4 harness already built in, so no need to separately order it.
My HIDs (low beams) throw so much focused light that I find my high beams don't add anything...the high beams' light isn't as "white" and it is more diffused, scattering light to the left (into oncoming traffic). And the HID low beams throw light MUCH further down the road than the high beams do.
For those reasons, I don't ever use my high beams. MY HID low beams are so good that the high beams are essentially useless.
The Lizzard
The original ACA did. The repro's harness for this wasn't built correctly, so we remove that portion and offer our 4 on harness as an option.
We can still get the original ACA with H9 bulbs, but they cost more. Demand isn't there so we don't bother stocking them.
Old Feb 25, 2014 | 07:06 PM
VETJAZZ's Avatar
VETJAZZ
I replaced my stock bulbs with HIR bulbs and added Radioflyers Hi-4 Harness so low beams stay on when you go to high beams. The light output is a huge improvement and it allows you to keep the stock housings and look. All for @ $100
Old Feb 25, 2014 | 07:47 PM
3318C5's Avatar
3318C5
Originally Posted by dangerz
Dude for as nice as your car is, you should really consider upgrading your headlights.
I'm not embarrassed to turn my headlights on now.
James this is what I have from JWM. Great product, instructions & support. HUGE diff when night driving!!
Old Feb 25, 2014 | 08:09 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Thx for the help.
Well….The short version: ACA was a manufacturer of the headlight lenses that included a true projector unit for the low beam and a reflector lens for the high beam. The low beams utilize an HID bulb effectively with a true focused beam. The high beam uses a standard halogen bulb in a reflector lens. Using an HID bulb in the high beam will be bright but not focus the beam and the light will be scattered. Note that the ACA low and high beam cannot be aimed individually and once the low beams are correctly aimed the high beams will be off. In most cases way to high.
Radioflyer and JWM are vendors here on the forum who both have product offerings based upon modified ACA headlights and their own proprietary units. I will leave it to Radioflyer, JWM and others to extol their own products and features. Radioflyer has also a modified ACA housing with a BiXeon projector (low and high in one projector).
I personally purchased by ACA units off the auction site originally. I then upgraded to a set by Radioflyer with the halo option and the high beam readjusted so that when the low beam is aimed correctly the high beam is not to high and effective, though my lows with the projector lens and HID bulb do not normally require the highs.
Old Feb 25, 2014 | 10:12 PM
WA 2 FST's Avatar
WA 2 FST
Thank you!
Old Feb 25, 2014 | 10:50 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
JW does not sell Sh!tty **** Anywhere,,,,Sh!thead from East Texas!
Can't wait to see you and the Mrs. at TMS
Old Feb 25, 2014 | 10:56 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Correct on the function of our headlights.
The factory draw on the headlights is 55w and in order to maintain proper headlight raise/lower function an HID kit must draw the same amount of power or the buckets will not work correctly.
Old Feb 26, 2014 | 12:47 AM
JETninja's Avatar
JETninja
WA Events Coordinator
Corvettemods is also like JWM....I have a set and love them, night and day difference over the stock lighting. I no longer fear driving in the dark, and have been doing it daily lately here in the PNW. Lifetime warranty too!
RF's are the top, but too pricey for me. (you get what you pay for though!)
Old Feb 26, 2014 | 02:56 AM
skydiven4fun's Avatar
skydiven4fun
St. Jude Donor '13-'14-'15
Got to have some good lights James, Your car deserves em
Old Feb 26, 2014 | 03:13 AM
1999Firehawkls1's Avatar
1999Firehawkls1
Left is HIRs in Stock Housings
Right is Completly Stock
Old Feb 26, 2014 | 03:18 AM
  #33
1999Firehawkls1
Im right along w ya, the stock lights gotta GO....before I spend big bucks on HIDs Im gonna try this and see if its what I want for $100+$25 for the "Hi 4" harness that RF sells I cant loose much!
I can not see how even the Lows on HIDs wouldnt blind on coming traffic and have them possibly hit ya head on....(Worst Case)
2nd if they are bright enough to blind on coming traffic, Cops are def gonna pull ya over ASAP
Old Feb 26, 2014 | 06:51 AM
  #34
1999Firehawkls1
Or these
http://forums.corvetteforum.com/c5-g...t-upgrade.html
Old Feb 26, 2014 | 08:44 AM
  #35
John Madeja's Avatar
John Madeja
Those look awesome
Old Feb 26, 2014 | 09:30 AM
  #36
TheRadioFlyer
Supporting Vendor
A good read:
Headlights: The Truth Illuminated. What works and What doesn't
Old Feb 27, 2014 | 02:00 AM
  #37
1999Firehawkls1
Originally Posted by theradioflyer
Good Info!
