Headlights ....
Old Feb 24, 2014 | 09:34 PM
James2002z06's Avatar
James2002z06
Default Headlights ....
I'm tired of not being able to drive at night ..... Without spending a small fortune is there a low beam light that's made for our cars that's worth a crap ?
Have any of you'll taken the high beam out and moved them to the low beam side ? Heck it can't be that much brighter cause they both suck ....
Old Feb 24, 2014 | 09:45 PM
ZFLASH's Avatar
ZFLASH
St. Jude Donor '10-'11-'12-'13-'14, '16
James,I have JW's lower opening version with out the shrouds, yes they're bit pricey,but are awesome. Also check out George's (Radioflyer) version,native Texan and seems to have great products. Good luck,L8R ZFLASH
Old Feb 24, 2014 | 09:48 PM
James2002z06
Thanks Flash .... I should have bought from JW last at the NCCO
Old Feb 24, 2014 | 09:49 PM
Kmcoldcars's Avatar
Kmcoldcars
With all the money you have spent on your car I do not think it would hurt TOO MUCH for you to spend $ 350 or so to get the projector kit from JW Motoring with the HI-4 harness. This gives you a HID low beam with a great light output that does not blind other drivers that stays on when you put on your high beams.
I got the 55 watt 5000K HID low beams for my Z06 and they throw out a wall of white light. Here are the pictures again.
Low beam.
Low and high beams together.
Old Feb 24, 2014 | 11:00 PM
dangerz's Avatar
dangerz
St. Jude Donor '09-'10
Dude for as nice as your car is, you should really consider upgrading your headlights.
I'm not embarrassed to turn my headlights on now.
Old Feb 24, 2014 | 11:30 PM
chasboy's Avatar
chasboy
Oldtimer
After wasting $40 on Ebay HID's, I bought PIAA low beam bulbs...I don't remember the model number now but it was listed as their brightest light and had good reviews. They are much brighter and whiter than stock. I also have that 'special' Toshiba bulb that is no longer made in the hi's. Light is similar temp to stock but brighter.
Old Feb 25, 2014 | 03:54 AM
o2bnkc's Avatar
o2bnkc
I just run my high beams all the time. I guess they aren't too bright, the oncoming traffic never flashes their lights at me.
Old Feb 25, 2014 | 04:00 AM
Low beam.
Great light output there.
Old Feb 25, 2014 | 05:03 AM
James2002z06
Thanks guys ..... I looked at corvette mods last night .... $299.00 shipped
Old Feb 25, 2014 | 08:58 AM
TXGS507's Avatar
TXGS507
I'm with Danger... #RadioFlyer...
Old Feb 25, 2014 | 09:14 AM
andrec10's Avatar
andrec10
Ordering mine from JWM by the end of the week. I too suffer from embarrassment when turning on my headlights!
Old Feb 25, 2014 | 09:43 AM
LoneStarLizzard's Avatar
LoneStarLizzard
If I'm not mistaken, JW's ACA HID kit comes with the Hi-4 harness already built in, so no need to separately order it.
My HIDs (low beams) throw so much focused light that I find my high beams don't add anything...the high beams' light isn't as "white" and it is more diffused, scattering light to the left (into oncoming traffic). And the HID low beams throw light MUCH further down the road than the high beams do.
For those reasons, I don't ever use my high beams. MY HID low beams are so good that the high beams are essentially useless.
The Lizzard
Old Feb 25, 2014 | 09:51 AM
darnplumber's Avatar
darnplumber
I need jnw! I thought only my Vette had awefull headlights...I also drive on high beams with nobody ever flashing me.
Old Feb 25, 2014 | 09:52 AM
kgie1217's Avatar
kgie1217
St. Jude Donor '14
The Lizzard
The Radioflyer headlights come with the Hi-4 harness with his kit. I have them on my car now. They are great!
Old Feb 25, 2014 | 11:05 AM
olbear1962's Avatar
olbear1962
I went with The Radio Flyers Bi-Xeon ACA light kits and harness.One of the best mods I have done. I can actually see the road at night!!
Old Feb 25, 2014 | 11:13 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Our Bi-xenon ACA headlights turn night into day and are completely bolt-on with no grinding, cutting splicing or drilling required.
This will give you an idea of the output (SLC V2 shown, but the same projector and HID kit are used on the Bi-xenon ACA kit)
Thank you for the kind words
Old Feb 25, 2014 | 12:59 PM
Cowboy26a's Avatar
Cowboy26a
Same here.
These are the lights GM should have put on at the factory.
To Headlights ....
Old Feb 25, 2014 | 02:04 PM
Bobd207s's Avatar
Bobd207s
From: Cancer Sucks - please donate to Corvettes Conquer Cancer
Cruise-In X Veteran
St. Jude Donor '08-'09
I also went with Radio Flyers kit and had him add the Krell LED bulb for my high beams and wow what a great setup !!! I drive a lot at nite and am Very Happy !!
Old Feb 25, 2014 | 03:44 PM
kgie1217's Avatar
kgie1217
St. Jude Donor '14
Same set up here!
Old Feb 25, 2014 | 05:23 PM
WA 2 FST's Avatar
WA 2 FST
I don't drive a lot at night, so I really have never been bothered by the lousy headlights.
But please help me with the nomenclature... I see ACA, JW, Radioflyer... modified ACA housings, Bi-xenon... etc.
I see some people are finding them for $300, and Radioflyer's kit is $650.
What is what? I don't want to cut corners. I'm a good shadetree mechanic, but I don't want to go cutting everything up to get something to work and find it doesn't fit right. I also want to do this ONCE and be done. I don't want too much electrical load/draw on my 12yr old factory wiring harnesses... to me that = fire hazard.
Thx for the help.
