improved headlights?
Old Mar 4, 2014 | 02:09 AM
john8642's Avatar
john8642
Default improved headlights?
Has anyone found replacement bulbs for the headlights that increase visibility without having to resort to a projector lens? I would love to get lights from radioflyer, but it's not in the budget right now.
Old Mar 4, 2014 | 02:19 AM
Chilliwack vettes's Avatar
Chilliwack vettes
Careful. That type of thinking can end up costing you a bunch more in the long run. Sometimes it's worth simply holding off on a mod to get what you really want.
Old Mar 4, 2014 | 06:57 AM
Tuscany's Avatar
Tuscany
Default HIDs
I put HID bulbs (plus ballasts) in mine, keeping the existing lenses. It was the first mod I did. I still love 'em.
Old Mar 4, 2014 | 07:27 AM
runner140*'s Avatar
runner140*
I drive at night seven days a week and use high beam bulbs in the low beam socket. They don't blind oncoming cars because they are adjusted for low beams. All you need to do is cut the ridge inside the high beam bulb.(knife)
Old Mar 4, 2014 | 07:43 AM
robertmc1958@gmail.c's Avatar
Check out the Sylvania Silverstar ZXE, Advance Auto $59.95(2 pack). I use them in all my vehicles and they are very bright.
Old Mar 4, 2014 | 07:52 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
https://www.corvetteforum.com/c5-general/3426040-factory-high-and-low-beams-suck-2.html
Try this thread.
Old Mar 4, 2014 | 12:28 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Very true. One of my customers about a year ago reported spending over $2000 over a few years trying NOT to get the headlights he really wanted in the first place.
We are planning to run a sale on the Modified Bi-xenon ACA headlights in about 1-2 weeks as soon as wee get more inventory.
Old Mar 4, 2014 | 02:45 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Look into the HIR halogen bulbs as well. Unlike putting HID bulbs in a reflector (stock) lens they will not scatter the light. There are varying opinions if they are better than the SilverStars or not. I use the HIR bulb in the high beam of my ACA type units from Radio Flyer to compliment the HID in the low beam projector. Works well for me and I think they are brighter than the SilverStars I had previously. You can run the HIR bulbs in the stock lenses as they come in a low or high beam. If I recall you have to make a slight modification to the locking tab to get them to fit if you want to also run the HIR high beam in the stock low beam as well as the high beam.
This may help:
http://blog.brianmoses.net/2013/11/a...-corvette.html
Old Mar 4, 2014 | 02:55 PM
66dts-v's Avatar
66dts-v
I got a pair of these at NAPA fro about $50. Sylvania Siverstar Ultra, what a HUGE difference over whatever was in there before.
https://www.sylvania.com/en-us/produ...tar-ultra.aspx
Old Mar 4, 2014 | 05:14 PM
VETJAZZ's Avatar
VETJAZZ
I replaced my stock bulbs with HIR's. I also installed Radioflyers Hi-4 Harness so low beams stay on when you go to big beams. Huge improvement in output without changing stock look and housings.
You need a pair of 9011 and 9012 bulbs.
http://www.ebay.com/itm/PHILIPS-9011...-/140607310182
http://www.ebay.com/itm/PHILIPS-9012...-/380758327730
The flange on these bulbs need to be trimmed to fit. Very easy to do. Here are instructions - http://shnu.us/HIR%20Trimming%20A.htm
For more background on HIR's, check this site - http://hirheadlights.com
Old Mar 4, 2014 | 05:32 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
If you are looking for a nice upgrade over stock without going full out HID projector lights, I can recommend what I did: PIAA Extreme White Plus headlights and Philips 893 CrystalVision driving lights.
Definitely an improvement that you will notice. However, I do not do much driving at night. If I did, I would be in on the radioflyer set up for sure.
Old Mar 4, 2014 | 05:48 PM
1BADAZ50TH's Avatar
1BADAZ50TH
But was not my first mod.
Old Mar 4, 2014 | 06:59 PM
john8642's Avatar
john8642
Thanks for all the suggestions. I'll probably go with the radioflier units.
Old Mar 4, 2014 | 07:07 PM
NinjaZX14r's Avatar
NinjaZX14r
You want a racehorse ......not a shetland pony when it comes to bright lights for your vette....take the time to save the money and get the Radioflyer bulb kits........only thing I can say is a 747 pilot would be proud to have these on his plane.....
It only costs 10% more to go first class...
Love mine!
Ninja
Old Mar 6, 2014 | 06:16 PM
Joe_A's Avatar
Joe_A
St Jude Donor '15
Another option is the E-Spec Headlights with high Watt bulbs.
It also is not a cheap option. But another way to get better lighting.
Here is a thread with lots of details.
http://forums.corvetteforum.com/c5-g...t-upgrade.html
Old Mar 6, 2014 | 08:35 PM
ALLEGRO's Avatar
ALLEGRO
I did the 9005 (high beam) conversion. BIG difference
I chose to use SilverStars in 9005, did the quick mod to the bulb socket and have enjoyed the results for years.
Good luck
Old Mar 6, 2014 | 09:27 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
JWMotoring Hids set up! I don't even use my high beams!
To improved headlights?
Old Mar 6, 2014 | 09:58 PM
Silverbullet00
Same thing I did,,,JW Motoring! Missed this post first time around!
Old Mar 7, 2014 | 04:46 PM
stevegray04's Avatar
stevegray04
St. Jude Donor '14
Subscribing to this thread along with others I read. The more opinions and advice, the better. Still trying to decide between Radioflyer bi-xenon, HIR bulbs, Silverstar (which I have now) and other setups people have chosen. The Silverstars are better than stock, but not by much. Decisions, decisions.
Old Mar 7, 2014 | 08:54 PM
TheRadioFlyer
Supporting Vendor
Something to consider: The factory headlights were designed to focus light into a small area directly in front of the car. Running silverstars, HIRs or even HIDs in these housings will only brighten this small area.
The Projector in our housings is design to illuminate an area nearly 10 times a large as the area illuminated by the factory lights and with the HID power source it has no problem doing this.
We will be having a sale on these lights very soon (within a week)
