Vara Junk
Old Mar 10, 2014 | 10:14 PM
StingrayRebel's Avatar
StingrayRebel
I agree that it is pretty poorly built but once you get it on right it does work... I ran one on mine for 3 years but recently took it off for a blower... I siliconed the filter into the upper housing because it would not fit the curvature very well and the foam seal they supply is garbage, it will fall off very quickly once it is heated up a few times... the silicone will force air to flow through the filter and not let any debris past the edges and to clean it just remove the upper housing, rinse with water, then let it dry... I never used filter oil because it can get past the filter and contaminate the maf
o2bnkc's Avatar
o2bnkc
Originally Posted by 3boystoys
Never understood all the KUDO's these thing get anyway, seems like a good way to flush several hundred $$$'s for little upside.
Do you have one?
Old Mar 11, 2014 | 01:54 AM
zagger's Avatar
zagger
Had both, the original and second gen Vararam. Both were POS as far as fit and finish. It is also ironic when some are defending the poor fitment and at the same time mention silicone, extra washers, etc. to make it work. Truth be told as bad as the finish is and no matter the gaps and holes it is probably best performing intake on the market to this day. Going back to design and finish. The runners and main body are vacuum formed ABS sheet, which is the cheapest material and way to fabricate them as appose to molding. The entire design, due to it's construction is rigid and hard to fit on a C5 where no two are really alike. If there were accordion style flex joints the system would be much easier to install and molding the filter housing would guarantee clean tight fit. But then you would have another $500 intake like the honker. In my humble opinion what you get in Vararam is a very good performance, low cost and extremely crappy fit/finish. You decide what is important to you, after all that has been posted on the subject over the years there should be no surprises.
Old Mar 11, 2014 | 07:43 AM
Black 02's Avatar
Black 02
Originally Posted by Dave_2003_TRZ06
my Vararam is sitting in the corner of my garage...fit and finish was terrible, only had it on the car a few months before going back to the Black Wing....
anyone local to cypress is more than welcome to come and get it out my garage....
I'm in jersey village and can never turn down free parts
Old Mar 11, 2014 | 08:16 AM
Dave_2003_TRZ06's Avatar
Dave_2003_TRZ06
You are most welcome to it
Old Mar 11, 2014 | 08:20 AM
Mattie Num Nums's Avatar
Mattie Num Nums
Mine was garbage too. Just honestly didn't fit. Me and a buddy managed to get it to finally go together and the gains were impressive. Its quite the paradox the Vararam is.
Old Mar 11, 2014 | 08:34 AM
helives4u2's Avatar
helives4u2
Originally Posted by RideZX6R
So you registered 2 months ago and we're going to totally count out user-error eh?
Cool man
I've had corvettes for over 10 yrs. If your criticism to yourself
Old Mar 11, 2014 | 08:36 AM
helives4u2's Avatar
helives4u2
What do you think of the Hurricane System?
Old Mar 11, 2014 | 10:00 AM
Patches's Avatar
Patches
I've had several different intakes over the years and I agree the Vararam doesn't stand out as the one with highest build quality. But it's useable and it gave me, by far, the greatest gains of any intake to date. I could easily feel the difference when I pulled my Blackwing off and installed the Vararam. Also, I logged intake temps with EFI Live and they never exceeded ambient while the underhood filters like the BW saw temps as much as 40 deg. above ambient.
This weekend, I uninstalled the Vararam from my C5 - not because I think it's garbage and doesn't work, but because I'm modding the car again and the Vararam will not work with what I'm doing. When I pulled the front fascia off I looked at the install and it was still rock solid and well sealed. If installed properly, the system seals well and performs better than anything else out there. If I could make it work with my new setup, it would be staying on the car. Unfortunately, it's for sale.
Say what you will, it does work as advertised.
I added an extra airbox clamp to each side for a tighter seal. My filter fits very snugly in there so no leaks. the throttle body blade was spotless when I pulled this off this weekend.
Old Mar 11, 2014 | 05:27 PM
zagger's Avatar
zagger
I have no personal experience with Hurricane but others who have it seam to like it. From personal experience the two systems I would recommend is the Vararam and Honker. Both constantly produce best gains over the entire C5 generation spectrum. One has very good fit and finish but costs about $500 and other less refine and probably will require additional fab to work but can be had for under $250. Just don't complain about the finish as you have been warned The reality is that stock system will easily support 450 HP and gains by all other systems are minimal at best. The computer on board C5 is very good at learning changes and canceling any power gains over time. Majority of people buying the CAI systems would benefit much more from a good tune than just simple bolt on CAI. Just my opinion
Old Mar 11, 2014 | 11:10 PM
Dave68's Avatar
Dave68
After attending a couple of Dyno Day events, I realized by the HP and TQ numbers for the many C5s tested that many of the intake/cat-back combos were very close, as far as net gains.
My Halltech?Borla combo gained as much as Vararam/Corsa or BPP/Magnaflow combos.
Remember that dyno tests are typically done with the car's hood, open. This allows heat that would normally get trapped in the engine bay (Blackwing, Halltech, etc), escape. There was a fan in front of each tested car, as well.
The difference among the intake systems comes on the road. True CAI systems pull in ambient air, whereas Blackwing and Halltech intakes pull in engine bay air. This is why I installed a cold air scoop to blast outside air past the filter element. This setup kept intake air temps far closer to ambient (I did a before and after test, using a car chip data logger plugged into the OBD II port.).
The advantage my setup has over closed systems (air filter is isolated from engine bay air) is that my engine bay and all its hoses, belts, batteries, and electronics stays much cooler than the engine bay where outside air is isolated. All my aforementioned OEM hardware (except the battery, of course) is still in perfect condition, thanks to that cooler air that pushes out the hot stuff.
Old Mar 11, 2014 | 11:12 PM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
100k+ miles with my Vararam. no complaints here.
Old Mar 11, 2014 | 11:38 PM
  #33
racebum's Avatar
racebum
so aftermarket parts don't fit like oem and may need some massaging
you don't say
Old Mar 11, 2014 | 11:46 PM
  #34
olbear1962's Avatar
olbear1962
you don't say
