Mobil 1
Old Apr 2, 2014 | 10:09 AM
TheBigDog's Avatar
TheBigDog
Default Mobil 1
Can someone explain the difference between SUPER full synthetic and the regular full synthetic ? They both come in the 5W-30 and there is a sale going on at Advance Auto.
Thanks,
The BigDog
Old Apr 2, 2014 | 11:12 AM
65GGvert's Avatar
65GGvert
Thanks,
The BigDog
Apparently "super" replaces Mobil 1 "clean" that is supposed to clean sludge. Here's a website I googled with faq's that answer if you read far enough.
http://www.mobil.com/USA-English-LCW...-oil-faqs.aspx
Old Apr 2, 2014 | 11:28 AM
Interesting. Didn't know there was a super full synthetic. Thanks for the link.
Old Apr 2, 2014 | 12:01 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
More decisions to make now on oil.
Old Apr 2, 2014 | 12:05 PM
Corvette_Ed's Avatar
Corvette_Ed
And more threads to create about which one is the best....
Old Apr 2, 2014 | 12:18 PM
GeneT's Avatar
GeneT
I've always used Mobil1 Hi-Mileage in my Corvette (now 40,000) and my SRX ( now60,000) because I assume it has more additives for seals, etc. There can't be much other difference.
Old Apr 2, 2014 | 02:33 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
Here is link for you use, to checkout the right oil for you.
http://www.mobiloil.com/USA-English/....aspx?option=2
Old Apr 2, 2014 | 02:44 PM
65GGvert's Avatar
65GGvert
According to the link I supplied, "super" now also replaces "hi mileage" Mobil 1.
Old Apr 2, 2014 | 06:45 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
It also has a higher ZDDP content...
Old Apr 2, 2014 | 07:15 PM
c4cruiser's Avatar
c4cruiser
Mobil-1 has been the factory fill for Corvettes since the LT1 was introduced in 1992. Mobil has probably improved the oil a number of times and I personally think some of the new oils are not really necessary for Corvettes like the C4 and C5.
Sure, the high mileage stuff can help., but with cars that have under something like 100K miles, any good quality full-synthetic that meets the current GM DEXOS1standard should work fine.
I'm using the standard Mobil-1 synthetic in my supercharged C5 and in my '87 autocross/track day car. Don't see any issues at all with that oil.
Old Apr 2, 2014 | 09:04 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
that is the key. You need ~1000 ppm to prevent premature wear of critical metal components.
Old Apr 2, 2014 | 10:14 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Been running off the shelf Mobil 1,,,,should I panic????? 94K on my cammed C5.
JK!
Old Apr 3, 2014 | 02:23 AM
Mr31FlavorsVette's Avatar
Mr31FlavorsVette
St. Jude Donor '12
According to Mobil USA: "Mobil 1 is part of our ultimate line of advanced full synthetics. It uses the latest in additive and base oil technologies that provide superior protection, and outperforms Mobil Super Synthetic."
Old Apr 3, 2014 | 05:55 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
There's something to be said for an oil that constantly has to reinvent itself. The message I get is it isn't good enough, or we found something not quite right with our product so we fixed it.
Old Apr 3, 2014 | 06:37 AM
memmer's Avatar
memmer
Not so,as we progress through time we learn more and more and improve as we go. Would you not say that the model T ford was not the best for it's time?And look at where we are now and where we will be in 10 years from now.Just saying.
Fred
Old Apr 3, 2014 | 07:49 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
The super synthetic oil has a little something special in it. I'm going to guess that most of it is advertising hype. I suppose they could have used the word "improved", but that doesn't sound as good as super. If you had your choice of a regular or super dinner at a restaurant, which one would you choose?
Old Apr 3, 2014 | 07:56 AM
leadfoot4's Avatar
leadfoot4
Originally Posted by c4cruiser
....Sure, the high mileage stuff can help., but with cars that have under something like 100K miles, any good quality full-synthetic that meets the current GM DEXOS1 standard should work fine.
Not really, because oil that meets the Dexos 1 standard, also meets the government's "SL" standard, which is the reduced ZDDP standard, which our C-5 were NOT necessarily designed to run on. The "high mileage" oils have the original ZDDP levels, because it's assumed that "high mileage" cars are older cars.....
You're forgetting that the EPA has also had a hand in motor oils being "re-invented".......
To Mobil 1
Old Apr 3, 2014 | 06:12 PM
Z06ufgrad2002
I found out the hard way using the "newer" and "Improved" oils. I lost my cam and lifters after 10+ years of no problems after using one of the "Newer" oils. That oil cost me a whole new bottom end and countless hours of work.
Please Choose your oil wisely and pay attention to the ZDDP content. Or you suffer the same fate I did.
Old Apr 3, 2014 | 06:23 PM
killain's Avatar
killain
Oldtimer
Default Oil & Insurance ?
I've been using Mobil-1 in my 2003 50th. Anniversary coupe since it was new. Been ten years now and I've never had a issue of any kind that would hint at a flaw. So since it has always worked excellent, and meets the New Dexos requirements I'll stick with it. I'm sure all the other synthetic oils are fine, but I don't look for things to fix if their not broken ?
Old Apr 3, 2014 | 06:40 PM
killain's Avatar
killain
Oldtimer
Default OIl & Oil ?
Is there any real difference between Mobil-1 and Royal Purple High Performance SAE 5W/30 ? Royal Purple also states on it's label it too meets Dexos1 Specs. ?
