Corvette C5 Whine while accelerating
Old Apr 13, 2014 | 01:54 PM
That1guy's Avatar
That1guy
Default Corvette C5 Whine while accelerating
During a recent trip SF to Las Vegas, and back, my Corvette started to make a whining sound. It only occurs during acceleration, and only in gears 4th, 5th and 6th. The whine seems unrelated to speed, take the foot off the gas, and the noise goes away.
When I put the car in neutral the noise goes away as well. I changed the transmission fluid, and the clutch fluid, and the noise is still there.
What are some things I can check to try and diagnose this issue.
Old Apr 13, 2014 | 01:56 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Have you looked under the hood, Maybe someone installed a supercharger...
Old Apr 13, 2014 | 01:57 PM
DSTURBD's Avatar
DSTURBD
Senior Member
Cruise-In V Veteran
Look for a supercharger you didn't know you had?!?!?!? J/K
Sounds like a weird one to me.
DSTURBD
Old Apr 13, 2014 | 01:58 PM
DSTURBD's Avatar
DSTURBD
Senior Member
Cruise-In V Veteran
Hey there Bill! Great minds think alike!! Check out our post times. We were typing the same thing at the same time!!
DSTURBD
Old Apr 13, 2014 | 02:00 PM
That1guy's Avatar
That1guy
No super charger
Old Apr 13, 2014 | 02:01 PM
rob-cyn's Avatar
rob-cyn
Are you sure it's not the rear end ? Mine whines once I get over 60. Let off the gas it goes way. Try feathering the throttle when it's at its most prominent. If it quietens down with very light throttle then my bet it's the rear. From what I have read its not a rare problem. I have learned to live with mine. Switched to royal purple fluids and it didn't help. I added 2 bottles of the GM rear end additive and it did help some but it's still there.
Old Apr 13, 2014 | 02:04 PM
That1guy's Avatar
That1guy
The vehicle is an 03, and the belt is original it may be team to swap out the belt. Are there things I should look at to tell if the harmonic balancer is bad?
The whine is a new sound, and it does seem to be worse the harder I accelerate.
No matter how hard I accelerate in 1 & 2 I dont seem to get the whine.
Old Apr 13, 2014 | 02:41 PM
DSTURBD's Avatar
DSTURBD
Senior Member
Cruise-In V Veteran
Just a thought, but that would tend to rule out RPM related issues like your belt. The rear end, however, would still be turning at lower speeds in lower gears regardless of load. Load could still be a factor as stated above, but maybe only at higher rotational speeds?!?
DSTURBD
Old Apr 14, 2014 | 01:13 AM
rob-cyn's Avatar
rob-cyn
Mine is an 03 6 speed. Started doing it with around 35000 miles. At 51000 now and it's still doing it. I find that it goes away completely when I have the stereo turned up really loud
Old Aug 30, 2015 | 06:34 PM
Mrcpudoc's Avatar
Mrcpudoc
1st Gear
Mine is also an 03 6 speed, coming up on 35k as well. I just noticed it the other day when I happened to to be driving with the top up and the radio off. I came here looking for what was wrong when I found this thread. Are you still going strong? It sounds like it's safe to ignore it. As little as I drive it I'll take a while to get to 51k. I just don't want to find myself stranded on the highway with diff failure.
Old Aug 30, 2015 | 07:14 PM
That1guy's Avatar
That1guy
The whining would go away completely I put it in neutral, or engaged the clucth. It wasnt related to rpm or speed. It has been currently diagnosed as a throwout bearing on the clutch. I will be fixing it within the next few months, and I'll post the results.
To Corvette C5 Whine while accelerating
